Vizio e470vl orange light only
  • 1beertap
    • Mar 2009
    • 219
    Hey Folks,
    I have a Vizio e470vl with an orange light only on the front. There is no picture or sound. The power supply seems to be good on the outputs but not the inputs coming from the mainboard. My feeling is that the eeprom has quit and needs to be replaced. Any ideas where the eeprom is located on the mainboard? I don't have a schematic or a pic of the bottom of the mainboard, but I think the chip is located at U14.
    Also, I have checked the power supply on the following pins:
    5v = 5.17v
    5v = 5.17v
    5v = 5.17v
    gnd = ok
    gnd = ok
    gnd = ok
    gnd = ok
    12v = 12.27v
    12v = 12.27v
    12v = 12.27v
    PS_ON = 1.17v
    1-ON/OFF = 0v
    LAMP = 0v
    DIM = .76v
    These readings were the same no matter if I pressed the on/off button. Thanks.
  • 1beertap
    • Mar 2009
    • 219
    Re: Vizio e470vl orange light only
    Sorry about the first images, but here are the correct ones.
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      Did you check the fuses on the mainboard? There are two small fuses near the larger white input connector.
      • 1beertap
        • Mar 2009
        • 219
        The two fuses tested good. There is a third fuse nearby, it tested good as well.
        • retiredcaps
          • Apr 2010
          • 9271
          Whenever I see the brand Vizio, I suggest people to test the voltage regulators. It only takes 5 minutes or less. Report your findings exactly as shown in my examples.
          --- begin sig file ---
          --- end sig file ---
          • 1beertap
            • Mar 2009
            • 219
            I'm not sure if there are any regulators under the shielding. The voltage regulators were tested as follows:
            LOC = U8
            LINE1 = 7805LT
            LINE2 = RAB003
            PIN1 = 12.26V
            PIN2 = 0V
            PIN3 = 5.03V
            LOC = U2
            LINE1 = 1117
            LINE2 =
            PIN1 = 2.05V
            PIN2 = 3.30V
            PIN3 = 5.14V
            LOC = U7
            LINE1 = 1117
            LINE2 =
            PIN1 = 2.04V
            PIN2 = 3.28V
            PIN3 = 5.12V
            LOC = U4
            LINE1 = 1117
            LINE2 =
            PIN1 = 0V
            PIN2 = 1.25V
            PIN3 = 3.31V
            LOC = U3
            LINE1 = L513
            LINE2 = G1084
            PIN1 = 2.06V
            PIN2 = 3.31V
            PIN3 = 5.12V
            LOC = U46
            LINE1 = 1117
            LINE2 =
            PIN1 = 2.02V
            PIN2 = 3.26V
            PIN3 = 5.12V
            LOC = TU5
            LINE1 = M022
            LINE2 = G1084
            PIN1 = 0V
            PIN2 = 0V
            PIN3 = 0.28V
            • 1beertap
              • Mar 2009
              • 219
              Anyone know where the firmware chip might be located on this board? I am now assuming it's located under the shielding where the processor resides.
              • Dgtech
                E. Technician
                • Apr 2009
                • 1462
                • Steeler
                I think at this point it's time to swap out the main board and be done with it.
                • MisterD
                  • Oct 2012
                  • 668
                  http://www.ernestos-electronics.com/...vl-eeprom-fix/
                  • hienton2
                    • Sep 2009
                    • 183
                    eeprom U14
                    http://www.ebay.com/itm/Vizio-E470VL...item1e7d7bfa49
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                      Acer Extensa EX2540-517V Notebook 15 Specification for Upgrade or Repair
                      This specification for the Acer Extensa EX2540-517V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EX2540-517V boardview and EX2540-517V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                      09-06-2024, 06:00 AM
                    • SS454
                      vizio e650i-a2 backlight flashes then turns off
                      by SS454
                      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                      panel: au optronics T650HVN05.4
                      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                      https://www.shopjimmy.com/vizio-56-0...-power-supply/
                      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                      08-20-2020, 03:57 PM
                    • mrtek
                      Vizio M65-C1
                      by mrtek
                      Hi.
                      picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                      When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                      This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                      07-14-2025, 07:28 PM
                    • dholley
                      Vizio TV E470VL SMPS Flucuation Output Voltage
                      by dholley
                      Would someone please help troubleshoot a Vizio 47" TV Switch Mode Power Supply with 5 volt output fluctuating voltage. The voltage fluctuates at 5 the volt output and at the Pulse Switch Modulating IC at VCC. I have the following notes:
                      1. The 3 main filter caps all have approximately 167 volts steady
                      2. I have replaced 4 mosfets next to what I think is called the inventor transformer (big black transformer) pictures attached
                      3. I have replaced Fuse F102 with an equivalent
                      4. I have check all diodes and caps and they seem to be ok
                      5. I replaced the 431...
                      01-20-2022, 03:12 PM
