SAMSUNG HP-T5054 will not turn on,clicks when power is applied to it
    Re: SAMSUNG HP-T5054 will not turn on,clicks when power is applied to it
    Then you will need to check the FETs that it protects.
    • Mr Fix it
      • Apr 2013
      • 22
      • US
      #42
      WHICH fets do i need to check,what is the best way to test them
        Can you get a picture of the bottom area under the fuse that blew?
        • Mr Fix it
          • Apr 2013
          • 22
          • US
          #44
          Full Board
          More Specific Area
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            #45
            I had 3 42" Samsung hp-t4254 and 1 hp-t4264 and 2 hp-t5054 and 2 hp-t5064 that I replaced the 6 1000uf, the 2 470uf, and the 2 2200uf caps and all 8 of them fired right up!
            Hope this helps someone!
            • Journey11
              Samsung TV won't turn on ... keeps cycling the power relay on & off
              by Journey11
              Hi All,
              First time posting here ... my name is Kevin but my friends call me Journey.
              I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
              After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
              It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
              07-04-2024, 02:44 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • masoksian
              Dell latitude e7470 not turn on .power buton on off and Run Power problem
              by masoksian
              I am dealing with the problem of turning on and off my Dell e7470 notebook.
              The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
              The system does not turn on, there is no post.
              I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
              The problem continues in the same way.
              I tried to turn on the Fn key, nothing came to the screen....
              02-15-2025, 12:08 PM
            • stylishconsultant
              un60j620dafxza - Samsung No Display Problem
              by stylishconsultant
              Hi All,
              Need help.
              I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
              So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
              problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
              might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
              09-04-2024, 03:26 AM
            • rgla
              Samsung UN65MU8000FXZA Dead NO power NO standby light won't turn on
              by rgla
              Hi. First time post. I've scoured the previous forums looking for info - there isn't much for my model
              UN65MU8000FXZA
              We had a power outage. Everything plugged into the Monster surge protector seems to be fine except my Samsung TV. It was dead when the power came back to the house.
              Here's what I've looked at:
              Unplugged main board from power supply - BACKLIGHTS COME ON.
              Ordered new main board - still didn't work. Not sure if used MB was DOA
              MAIN BOARD = BN94-12295K
              PSB= BN44-00912 L65E8NR_MHS
              There...
              11-27-2021, 02:20 PM
