SAMSUNG HP-T5054 will not turn on,clicks when power is applied to it
  • Mr Fix it
    • Apr 2013
    • 22
    • US
    Re: SAMSUNG HP-T5054 will not turn on,clicks when power is applied to it
    here are pictures ,ihope they will help
      The connector to the right has PSON and VSON, does that go to the main board?
      • Mr Fix it
        • Apr 2013
        • 22
        • US
        I see the connector with PSON and VSON,It goes from PS board to control board.Do you still want me to check for polarity?
          I'm thinking that it's going to be difficult to test it due to the odd design Samsung have used. I think the main board is the fault. There appears to be a PS-ON on the connector (no VS-ON though) going to the main board. Can you check what voltage appears on there?
          • Mr Fix it
            • Apr 2013
            • 22
            • US
            I checked PS-ON pin at the PS BOARD WITH POWER PLUGGED IN ,iGET LESS THAN ONE VOLT. It changes a little .096 to.149 when it clicks.
              That's with the main board disconnected though? Can you try with it plugged in?
              • Mr Fix it
                • Apr 2013
                • 22
                • US
                #27
                I tried both ways,the readings i gave you are with it connected,without it connected I get constant .664 and it doesn't click when disconnected from PS board
                  Well, the reading is unexpected. Can you check what the PS-ON is doing on the connector going to the control board?
                  • Mr Fix it
                    • Apr 2013
                    • 22
                    • US
                    #29
                    The ps-on on the connector going to control board,with it connected and power on it has .000 to.9 as it clicks
                    • Mr Fix it
                      • Apr 2013
                      • 22
                      • US
                      #30
                      I checked all the pins at the ps board on the connector going to main board,with power applied,I did not have power on any of them. I did the same on the connector going to control board,i had no power on them either
                        What range do you have your multimeter set to?
                        • Mr Fix it
                          • Apr 2013
                          • 22
                          • US
                          #32
                          I HAVE BEEN CHECKING VAC,SHOULD I BE LOOKING FOR DC voltage
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            Yes, DC voltage.
                              And use 20VDC range.
                              • Mr Fix it
                                • Apr 2013
                                • 22
                                • US
                                #35
                                I checked ps-on on both connectors,on main board it's 0.00,on the control board it's 0.00to0.20
                                  That is not right at all. I suspect a problem with your meter or you are not probing correctly. What are you using as ground?
                                  • Mr Fix it
                                    • Apr 2013
                                    • 22
                                    • US
                                    #37
                                    first i did get a better ground,screw on corner of the board.I disconnected the connector to main board,with power on ,i checked PS-ON PIN I have constant 3.8vdc with it connected it goes from 3.34 to .245 to OL THEN CYCLES OVER AND OVER THESE NUMBERS. With connector to control Board connected PS-ON PIN goes from .244 to OL as it clicks,with it disconnected it goes from 3.34 to .245 to OL then it cycles thru over and over.I hope you can understand what i am saying.
                                      That makes more sense. This tells us a LOW signal turns the power supply on. So, get the resistor and put it from PS-ON to RTN or GND (whichever is present.) Then do the 3-4 jumper with LVDS removed from the control board, and see if test patterns appear.
                                      • Mr Fix it
                                        • Apr 2013
                                        • 22
                                        • US
                                        #39
                                        when i install the resistor, i do keep the main board connector connected.what return do i connect to ?,is the test pattern i am looking for on the tv screen ?
                                        • Mr Fix it
                                          • Apr 2013
                                          • 22
                                          • US
                                          #40
                                          I checked all the fuses again , the fuse in the center of the power board was blown,I replaced it when i connected power and turned it on it blowed again.
                                          • Journey11
                                            Samsung TV won't turn on ... keeps cycling the power relay on & off
                                            by Journey11
                                            Hi All,
                                            First time posting here ... my name is Kevin but my friends call me Journey.
                                            I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                            After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                            It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                            07-04-2024, 02:44 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • masoksian
                                            Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                            by masoksian
                                            I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                            The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                            The system does not turn on, there is no post.
                                            I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                            The problem continues in the same way.
                                            I tried to turn on the Fn key, nothing came to the screen....
                                            02-15-2025, 12:08 PM
                                          • stylishconsultant
                                            un60j620dafxza - Samsung No Display Problem
                                            by stylishconsultant
                                            Hi All,
                                            Need help.
                                            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                            09-04-2024, 03:26 AM
                                          • Cooperr
                                            Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                                            by Cooperr
                                            I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                                            The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                                            10-21-2025, 01:11 PM
