Hey all. Well this tv landed in my lap and I am stumped to say the least. Love to hear some input on this as I have devoted two days into it so far. Sus out ipm popped. Replaced and for good measure replaced er ipm as well. Now I have a picture back but dim. Not a zsus issue as I have another exact set with a tested working zsus. This is not a blotchy dim mal discharge dim but just dim like the contrast level is cranked all the way down. I tested the board in the other tv with same results. Now what's interesting is that the ramp up circuit had a shorted r73. Replaced and still dim. Also found b47 b48 b28 b39 open. Replaced all and still dim. R7 and r8 r75 r79 all ok. All voltages on the board appear to be proper. I don't have a schematic on the board but have a good one I'm testing readings against. Cannot find the issue. Anyone had this problem after replacing the faulty ipm's? It's for sure in the ysus as a good one works fine in this tv and gives the screen a bright raster. The board is the dreaded 6871qyh039a
Vizio p50hdm dim screen
Re: Vizio p50hdm dim screen
The IPM cannot fail "half power". Only the Z-sus IPM or bad priming on Y-sus can cause dim image.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
-Vy and Vsc, plus a few transistors, optocouplers, capacitors etc.
Negative period is important for erase and stability (sparklies.)
Positive period is important for brightness, black level and stability.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ok so I have a grey panel on prime. It does have a so called prime upon startup. But the to e is very dim. Kind of like when you disconnect the zsus but not the blotchy picture you would see. The zsus is working at capacity. The ysus seems to be outputting proper -vy and vscan voltages as well. Although the modules are not getting as warm as I am used to.
Note that there was a failure of a resistor off the -vy poteometer and it was replaced as well as the "inductive links"? On the diodes under the sus out ipm. All restored and no change. This ones a head scratcher. I should probably have a look at the optos on the circuit but the voltages are there and does respond to adjustments.Did I leave the soldering iron on?
See for alignments:
http://www.tgohome.com/ServiceManual...&Search=SubmitPlease do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I'm fairly sure Vsc should be positive. There could be a bad cap on Vsc output.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
The panel guide I linked to should make it clear, but for an X3-series plasma panel 115V seems too low to me.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
