Vizio p50hdm dim screen
    Hey all. Well this tv landed in my lap and I am stumped to say the least. Love to hear some input on this as I have devoted two days into it so far. Sus out ipm popped. Replaced and for good measure replaced er ipm as well. Now I have a picture back but dim. Not a zsus issue as I have another exact set with a tested working zsus. This is not a blotchy dim mal discharge dim but just dim like the contrast level is cranked all the way down. I tested the board in the other tv with same results. Now what's interesting is that the ramp up circuit had a shorted r73. Replaced and still dim. Also found b47 b48 b28 b39 open. Replaced all and still dim. R7 and r8 r75 r79 all ok. All voltages on the board appear to be proper. I don't have a schematic on the board but have a good one I'm testing readings against. Cannot find the issue. Anyone had this problem after replacing the faulty ipm's? It's for sure in the ysus as a good one works fine in this tv and gives the screen a bright raster. The board is the dreaded 6871qyh039a
    Re: Vizio p50hdm dim screen
    If its any help the sus out ipm is warm but not as warm as I think it should be as the er ipm is a but warmer. Zsus ipm's are obviously working as they are both decently warm and the same temp as each other.
      I'm now under the assumption that the ysus sus out ipm is not under full power. Leaving a very dim but uniform screen.
      Any input on this board would be greatly appreciated.
        The IPM cannot fail "half power". Only the Z-sus IPM or bad priming on Y-sus can cause dim image.
          Ah yes the priming. Don't mean to sound dumb as I am very fluent in
          Power supplies but on this board the priming is done by which circuit? Is it -vy?
            -Vy and Vsc, plus a few transistors, optocouplers, capacitors etc.
            Negative period is important for erase and stability (sparklies.)
            Positive period is important for brightness, black level and stability.
              Ok so I have a grey panel on prime. It does have a so called prime upon startup. But the to e is very dim. Kind of like when you disconnect the zsus but not the blotchy picture you would see. The zsus is working at capacity. The ysus seems to be outputting proper -vy and vscan voltages as well. Although the modules are not getting as warm as I am used to.
              Note that there was a failure of a resistor off the -vy poteometer and it was replaced as well as the "inductive links"? On the diodes under the sus out ipm. All restored and no change. This ones a head scratcher. I should probably have a look at the optos on the circuit but the voltages are there and does respond to adjustments.
                You may need to borrow a scope to test it. Also check Vzbias on Z-sus.
                  Z board is fine. Just tried again by swapping this y board into a working tv and same result. I am seeing different readings on the ic20 regulator for the input side of the sus ipm
                    Anyone ever had other problems with this board after an ipm replacement? It's obviously not priming the panel right although the output voltages seem ok with -vy at -200 and vsc at 115
                      Vsc sounds a little low? Should be around 180~190V for these panels.
                        Really? The panel sticker is extremely vague
                          115V is Vzbias.
                          What panel does this TV have? LG PDP50X3, LG PDP50X4?
                            What's the proper way to check vscan voltage on this board?
                              Is a pdp50x3
                              115V is Vzbias.
                                See for alignments:
                                http://www.tgohome.com/ServiceManual...&Search=Submit
                                  Well sure enough I get from -63 to max -145v on vsc test points and the +VSC pot on ps102 pack is where I am adjusting for the voltage adjustments. Not getting to -189v..
                                    I'm fairly sure Vsc should be positive. There could be a bad cap on Vsc output.
                                      Is the adjustment +VSC the vscan adjustment. If it is and what I have found on the sticker in the panel +VSC is 115v. Is this vscan?
                                        The panel guide I linked to should make it clear, but for an X3-series plasma panel 115V seems too low to me.
