Vizio p50hdm dim screen
  • freakaftr8
    • Oct 2012
    • 3743
    Hey all. Well this tv landed in my lap and I am stumped to say the least. Love to hear some input on this as I have devoted two days into it so far. Sus out ipm popped. Replaced and for good measure replaced er ipm as well. Now I have a picture back but dim. Not a zsus issue as I have another exact set with a tested working zsus. This is not a blotchy dim mal discharge dim but just dim like the contrast level is cranked all the way down. I tested the board in the other tv with same results. Now what's interesting is that the ramp up circuit had a shorted r73. Replaced and still dim. Also found b47 b48 b28 b39 open. Replaced all and still dim. R7 and r8 r75 r79 all ok. All voltages on the board appear to be proper. I don't have a schematic on the board but have a good one I'm testing readings against. Cannot find the issue. Anyone had this problem after replacing the faulty ipm's? It's for sure in the ysus as a good one works fine in this tv and gives the screen a bright raster. The board is the dreaded 6871qyh039a
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Vizio p50hdm dim screen
    If its any help the sus out ipm is warm but not as warm as I think it should be as the er ipm is a but warmer. Zsus ipm's are obviously working as they are both decently warm and the same temp as each other.
    • freakaftr8
      • Oct 2012
      • 3743
      I'm now under the assumption that the ysus sus out ipm is not under full power. Leaving a very dim but uniform screen.
      Any input on this board would be greatly appreciated.
        The IPM cannot fail "half power". Only the Z-sus IPM or bad priming on Y-sus can cause dim image.
        • freakaftr8
          • Oct 2012
          • 3743
          Ah yes the priming. Don't mean to sound dumb as I am very fluent in
          Power supplies but on this board the priming is done by which circuit? Is it -vy?
            -Vy and Vsc, plus a few transistors, optocouplers, capacitors etc.
            Negative period is important for erase and stability (sparklies.)
            Positive period is important for brightness, black level and stability.
            • freakaftr8
              • Oct 2012
              • 3743
              Ok so I have a grey panel on prime. It does have a so called prime upon startup. But the to e is very dim. Kind of like when you disconnect the zsus but not the blotchy picture you would see. The zsus is working at capacity. The ysus seems to be outputting proper -vy and vscan voltages as well. Although the modules are not getting as warm as I am used to.
              Note that there was a failure of a resistor off the -vy poteometer and it was replaced as well as the "inductive links"? On the diodes under the sus out ipm. All restored and no change. This ones a head scratcher. I should probably have a look at the optos on the circuit but the voltages are there and does respond to adjustments.
                You may need to borrow a scope to test it. Also check Vzbias on Z-sus.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Z board is fine. Just tried again by swapping this y board into a working tv and same result. I am seeing different readings on the ic20 regulator for the input side of the sus ipm
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Anyone ever had other problems with this board after an ipm replacement? It's obviously not priming the panel right although the output voltages seem ok with -vy at -200 and vsc at 115
                      Vsc sounds a little low? Should be around 180~190V for these panels.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Really? The panel sticker is extremely vague
                          115V is Vzbias.
                          What panel does this TV have? LG PDP50X3, LG PDP50X4?
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            What's the proper way to check vscan voltage on this board?
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              Is a pdp50x3
                              Originally posted by tom66
                              115V is Vzbias.
                                See for alignments:
                                http://www.tgohome.com/ServiceManual...&Search=Submit
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Well sure enough I get from -63 to max -145v on vsc test points and the +VSC pot on ps102 pack is where I am adjusting for the voltage adjustments. Not getting to -189v..
                                    I'm fairly sure Vsc should be positive. There could be a bad cap on Vsc output.
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      Is the adjustment +VSC the vscan adjustment. If it is and what I have found on the sticker in the panel +VSC is 115v. Is this vscan?
                                        The panel guide I linked to should make it clear, but for an X3-series plasma panel 115V seems too low to me.
                                        • spice_disc
                                          Vizio TV M50-C1 reboot cycle and static on screen
                                          by spice_disc
                                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                          09-08-2024, 02:37 PM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • Yehuda170
                                          ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
                                          by Yehuda170
                                          original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
                                          replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
                                          now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
                                          with original broken screen i can see in device manager touch screen in human interfaces
                                          but with the new screen it's not showing in device manager
                                          is it lenovo blocking it? is it driver missing?
                                          I²C is a headache
                                          07-14-2023, 01:29 AM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
