Toshiba 42HL67US blows fuses.
  • wickedwill
    • Apr 2013
    • 21
    • usa
    My dad asked me to take a look at this tv and i am not really a tv repairman. i do work on computers so i a little familiar..
    PROBLEM:
    He states that tv worked fine before a power failure. when power was restored tv failed to work. he brought it to me.. i observed no red led when plugged in. so i took off back.. replaced fuse. plugged in and poof. fuse popped immediately.
    not sure what to do next.. i suspect rectifier but there appears to be more than one.. help
  • capkid
    • Oct 2010
    • 1339
    Re: Toshiba 42HL67US blows fuses.
    I could be wrong, but this seems like a time-consuming endeavor. You could be walking into a minefield of issues with a failure caused by a power outage. Unless you're looking to turn this into a learning experience and you're not pressed for time, I'd just buy a replacement power supply. I saw a couple used supplies for this particular TV on eBay for less than $50.
    LG Plasma Mal-Discharge Correction Service
    • wickedwill
      • Apr 2013
      • 21
      • usa
      Originally posted by capkid
      I could be wrong, but this could be a time-consuming endeavor. Unless you're looking to turn this into a learning experience and you're not pressed for time, I'd just buy a replacement power supply. I saw a couple used supplies for this particular TV on eBay for less than $50.
      well i am always eagor to learn a thing or two..and from what i can tell, this could teach me how to make a few dollars.. many lcd tvs in the garbage lately. suspect most may not be really hard to fix...hopefully..
      • wickedwill
        • Apr 2013
        • 21
        • usa
        forgot to include picture of power board
        • capkid
          • Oct 2010
          • 1339
          I thought the same thing when I first started fixing TVs; the fixes shouldn't be that hard..."probably just blown caps". I can't remember the last time I fixed a TV that only had blown caps.
          I'd check the bridge rectifier(s) first, since your fuse is blowing.
          • wickedwill
            • Apr 2013
            • 21
            • usa
            i am not sure which one is the rectifier(bridge) as i see two on the board.. one is attached to a heat sink.. the other is near fuse where ac comes in
            • retiredcaps
              • Apr 2010
              • 9271
              While possible, I have never seen more than one bridge rectifier on a power board. It is that long black 4 pin device just SE of the glass fuse.
              With power off you want to see if it shorted between pins 1-2, 1-3, 1-4, 2-3, 2-4 and 3-4. Report all 6 ohms readings.
              --- begin sig file ---
              --- end sig file ---
              • retiredcaps
                • Apr 2010
                • 9271
                The one attached to the heatsink is likely your power mosfet. You can see if it is shorted using the same test method I wrote for the bridge rectifier.
                • wickedwill
                  • Apr 2013
                  • 21
                  • usa
                  ok i am gonna test the one you said should be the bridge..the one that is attached to heat sing looks like the other one it has 4 leads also.. but i will check.. one question though you say i shoud check ohms.. my meter has diode meter. should i use that? if not and i use ohms.. what level should i set it at?
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    If you have a manual meter, set it to two hundred (200). See this post (section on multimeter and shorted mosfet)
                    https://www.badcaps.net/forum/showpo...4&postcount=19
                    • wickedwill
                      • Apr 2013
                      • 21
                      • usa
                      assuming 200k ohm settings...
                      pin 1-2, 131.1
                      pin 1-3, 133.0
                      pin 1-4, 00.1
                      pin 2-3, no number or 1
                      pin 2-4, 130.1
                      pin 3-4, 132.3
                      if u need me to include numbers for diode meter...
                      pin 1-2, 563
                      pin 1-3, 562
                      pin 1-4, 001
                      pin 2-3, 1399
                      pin 2-4, 563
                      pin 3-4, 562
                      hope this helps
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        pin 1-4, 00.1
                        Remove this component and retest out of circuit. If pin 1-4 still reads 0.1 ohms, then it is shorted (bad).
                        A shorted bridge rectifier and/or power mosfet will cause the fuse to go .
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          With power off
                          Just for your education, resistance readings are always done with power off and the device unplugged from the AC outlet.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Check the power mosfet as well. It is not uncommon to have multiple shorted components depending on the nature of the failure.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Currently, feedback according to most regulars and professional techs here on badcaps, the percentage of TVs fixed due purely to obviously bad caps is around 5% or less.
                              Knowing how to troubleshoot a SMPS power supply, IMHO, is a good lifelong skill to have since almost every modern consumer electronic device that is AC mains powered has one.
                              • wickedwill
                                • Apr 2013
                                • 21
                                • usa
                                ok got that rec out..
                                seems pin 1-4 whether i use red on 1 and black on 4..or reverse that.. gets no reading..
                                have ot checked the mosfet yet.. gettin late.. but will do first thing in morning if ness..
                                  Please clarify "no reading": what do you see on your meter?
                                  • wickedwill
                                    • Apr 2013
                                    • 21
                                    • usa
                                    well i am a bit confused.. when i set multimeter to 200 ohm i not really gettin any readings at all, but when i set it to 200k i can get some numbers.
                                    also when i set it to diode mode and check this is what i get IN DIODE MODE,
                                    starting with red pin on the + terminal going left to right (+ ~~ -)
                                    +=1
                                    ~=2 and 3
                                    -=4
                                    pin 1-2 nothing just a 1 on left side
                                    1-3 same as 1-2
                                    1-4 same as 1-2
                                    red on 2
                                    2-1, 554
                                    2-3, no number
                                    2-4 no number
                                    red on 3
                                    3-1 551
                                    3-2 no number
                                    3-4 no number
                                    red on 4
                                    4-1 1274
                                    4-2 552
                                    4-3 554
                                    i hope this helps.. i cannot seem to get numbers when in ohms (200) just a quick flash
                                    • multimeter
                                      • Jan 2011
                                      • 739
                                      • united kingdom
                                      +=1
                                      ~=2 and 3
                                      -=4
                                      1-3 same as 1-2
                                      1-4 same as 1-2
                                      red on 2
                                      2-1, 554
                                      2-3, no number
                                      2-4 no number
                                      red on 3
                                      3-1 551
                                      3-2 no number
                                      3-4 no number
                                      red on 4
                                      4-1 1274
                                      4-2 552
                                      4-3 554
                                      in addition to retired caps post ,another way you can test the bridge...
                                      set meter to diode test
                                      pins 1 and 2 should have reading one way when reversing leads
                                      pins 2 and 3 should have no reading either way when reversing leads
                                      pins 3 and 4 should have reading one way when reversing leads
                                      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                                      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                                        Take the resistance reading of pad 1 and pad 4 where the rectifier was soldered to those pads, I believe you have shorted load.
                                        The four pin device ont he heatsisnk looks like anothe bridge also.
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
