Toshiba 42HL67US blows fuses.
    Re: Toshiba 42HL67US blows fuses.
    That sounds like some kind of mains surge could have damaged the TV. Also some generators can put out too high of a voltage if the load is suddenly removed.
    Measure the capacitor with a ruler, then we can suggest replacements, cost should be less than $10 total.
      Tell your dad to have some load connected to the generator output all the time, 100W lamp will be good. The regulation of the generator is very slow and the output voltage can swing wildly when it first comes on with no load.
        8.5cm diameter?? Sure about that?!
        • multimeter
          • Jan 2011
          • 739
          • united kingdom
          #44
          Originally posted by wickedwill
          this is my dads tv.. he said that what happened...
          power failed.. then his generator came on.. tv worked.
          when power came back and generator powered down and house power(ac?) came up tv stopped workin.. that is all i had to go by
          it is 200v 560 uF and i do not have a way to measure.. but.. it is about the size of a quarter in diameter.
          other number on it.. KMQ 77s108? nippon chemi? 105 degrees
          found tape measure.. 2.5 cm tall NOT including legs..8.5 cm diam.
          dont you mean 8.5mm diam?,jeesh sounds more like a nuclear warhead
          fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
          please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
          • wickedwill
            • Apr 2013
            • 21
            • usa
            #45
            where i got 8.5 cm.. i measured around the cap with a measuring tape.. if only across...approx 2.6 cm
              That sounds more reasonable!
              Replacement:
              http://www.digikey.com/product-detai...789-ND/1755454
              +$3 shipping
              • wickedwill
                • Apr 2013
                • 21
                • usa
                #47
                Replacement:
                +$3 shipping
                about to order.. one question bout this one u sent me link to...
                it says 85 degrees.. and mine says 105 on it.. is that a big diff?
                  Good point. For better reliability, may be best to pick this one:
                  http://www.digikey.com/product-detai...1616-ND/483214
                  (it would only affect the reliability in future.)
                  Oh, and check the lead spacing will fit too.
                  • wickedwill
                    • Apr 2013
                    • 21
                    • usa
                    #49
                    just got part about an hour ago.. installed cap..ty so very much.. works great...
                      Excellent to hear. Tell your Dad to heed the advice about the generator -- next time it might not be so easy!
                      And this should be a clue to others as to why we insist on pictures of the actual boards (not stock pics) -- otherwise the bad cap may not have been spotted!
                      • capkid
                        • Oct 2010
                        • 1339
                        Nice. Glad you didn't take my initial advice
                        LG Plasma Mal-Discharge Correction Service
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #52
                          Testing the board for shorts doesn't take very long and is super easy. For any board, I can generally do it in less than 5 minutes.
                          Finding the short, however, is a different matter. Murphy says it was always be the last component you desolder that is shorted.
                          For a 19 inch Dell lcd computer monitor, there is a short on the logic board. I looked at the 20 or so small caps and I decided not to even bother trying.
                          As we always stress, pictures of your boards matter. There have been a few self proclaimed "professionals" that think there is no sense posting a picture of the board even when we ask nicely. Another easy thread to hit close window and move on.
                          --- begin sig file ---
                          --- end sig file ---
                            Surface Mount Fuses Fundamentals Datasheet
                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                            10-07-2024, 06:07 AM
                            09-06-2024, 05:27 AM
                            09-06-2024, 05:59 AM
