Samsung 40C5000QF intermittent won't power on
  • smason
    • 1652
    This Samsung LCD goes through spurts where it won't power on, just clicks.
    Then it'll be fine for a while.
    I figured it'll just be a recap, but it's one of those super slim TVs, with long skinnySamwah caps.
    What's a good source for replacement caps in this form-factor?
    Re: Samsung 40C5000QF intermittent won't power on
    I wouldn't immediately consider bad capacitors.
    Have you checked the PSU voltages when it will and won't power up?
    • smason
      • 1652
      No, I haven't done anything other than take the back off since it arrived.
      Haven't even plugged it in.
      House-full of people to feed today so won't get at it 'till Monday or Tuesday.
      I assumed caps because the symptom is the same as the poster child for the Samsung bad caps class action lawsuit.
        But in those instances the capacitors almost always bulged; I'll bet yours haven't?
        • retiredcaps
          • Apr 2010
          • 9271
          I remember seeing some United Chemi-con long skinny caps in another picture and it looks like they have 2 possible series that might work?
          http://www.chemi-con.co.jp/e/catalog/index.html
          Check out KXJ and KHE.
          --- begin sig file ---
          --- end sig file ---
          • smason
            • 1652
            You'd win that bet, flat as pancakes.
            • smason
              • 1652
              Excellent, thanks!
              • smason
                • 1652
                OK, did some testing. Of course it behaves fine on the bench.
                Got some more details from "the customer"he says it randomly powers itself off, then back on, and sometimes stays off and won't power on, just clicks.
                Voltages on the power supply look good, maybe a hair high 5.3v 12.8v
                Voltage regulators on the main boardhave good outputs well within spec.
                For grins I measured the larger electrolytics on the power supply board. They're all in pairs in parallel, so not really too valid a test, but got readings that looked normal.
                I'm tempted to give it back and tell him to bring it back to me when it fails and stays failed
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Intermittent problems are always difficult.
                  I have an ATX power supply (it was under warranty) that was intermittent. Now it is finally failed, but the form factor and tight spacing makes it virtually impossible to troubleshoot.
                  • smason
                    • 1652
                    Indeed that's what I'm doing. Giving it back to "the customer" and he'll let me know if/when it fails for good.
                    • Mt.Man
                      • 53
                      Look for cracked solder connections on all the small transformers. Common problem on these Samsung thin TV power boards. But you may have a main board thats acting up.
                      • C152Heavy
                        by C152Heavy
                        Summary for TL-DR readers:
                        • VCC pin (18) of PFC...
                        01-11-2023, 02:53 PM
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                      • mrtek
                        Samsung UN43NU6950FXZA No power
                        by mrtek
                        Hi
                        Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                        Main fuse = OK
                        Back light LED = OK. Power them with aux power source
                        LED output = OK 156V
                        I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                        Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                        07-20-2025, 08:06 PM
