Projector cooling fan backup supply
  • japlytic
    • Oct 2005
    • 2086
    In Silicon Chip magazine, I have read about the premature failure of a lamp in a projector which has not had time to cool down (runs the internal fan for some time after turning it off at its own switch) due to a lengthy power failure.
    Should projectors have a backup battery which only runs the fan when power to the projector is lost?
    Also, I think the battery should be checked by the projector to see if it is fully charged and OK before the projector can be turned on.
    Re: Projector cooling fan backup supply
    Well, possibly, but few manufacturers would bother. Not their problem if the bulb goes pop...
    • randtek
      • Oct 2011
      • 280
      • US
      This probably would not be an effective solution. First, it would require space inside the unit for the battery, increasing size, weight, shipping costs etc. 2nd, it would only prevent a very few premature lamp failures, since lamps only fail this way a small percentage of the time when power is lost. Usually the lamp just cools slower, but no long term damage is done to it. Third, a projector housing is a very warm environment which would probably result in premature battery failure. For all of these reasons, a battery as part of the unit would not be practical. If you are concerned about this fairly uncommon occurrence causing a premature lamp failure for you, I would suggest getting an UPS (uninterruptable power supply) to hook up to it.
