Newbie with a Vizio VA370M
  • BTimm
    • Mar 2013
    After owning a Vizio VA370M for two years (about 2 weeks after the extended warranty expired) the sound started going and the video started "pausing" (for lack of a better word.) This happens on all inputs - cable, hdmi, gaming, pc etc.
    I am not an electronics expert, but this was a great TV. I am simply thinking about replacing boards, but could use some help knowing which boards might most likely be the culprit.
    Any help would be appreciated.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Newbie with a Vizio VA370M
    Moved from FAQ.
    Are the caps on the various boards in good shape? I once had some cheapie GFM LCD tv gifted to me with of all things a sound issue... turns out some blown capxons on the PSU board were to blame.
    Beyond that, I'd need more info (pictures of the boards) and perhaps more knowledge (I'm not one of "the experts" in this subforum).
    sigpic
    (Insert witty quote here)
    • SS454
      vizio e650i-a2 backlight flashes then turns off
      by SS454
      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
      panel: au optronics T650HVN05.4
      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
      https://www.shopjimmy.com/vizio-56-0...-power-supply/
      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
      08-20-2020, 03:57 PM
    • mrtek
      Vizio M65-C1
      by mrtek
      Hi.
      picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
      When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
      This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
      07-14-2025, 07:28 PM
    • howardc64
      Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
      by howardc64
      Failure Symptom
      No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
      Where is the short?
      Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
      Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
      05-27-2025, 02:56 PM
    • howardc64
      Vizio SmartCast TV software bug that looks like hardware
      by howardc64
      Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
      It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
      11-16-2024, 05:17 PM
