Element ELCHW402 - Will not turn on!
  • whatusername
    • Dec 2013
    • 456
    Re: Element ELCHW402 - Will not turn on!
    plain bill gave someone part numbers in a different thread on this model tv i ordered it from Digikey and the tv works again.. $3 fix Thanks plain bill wherever you are
    • shannon2641
      • Jun 2014
      • 10
      • United states
      so what are the part numbers?
      • Agent24
        I see dead caps
        • Oct 2007
        • 4959
        • New Zealand
        Check here: https://www.badcaps.net/forum/showth...light=ELCHW402
        -David VanHorn
        • whatusername
          • Dec 2013
          • 456
          iDgikey 495-3799-ND and 399-5982-ND both Will work
          • shannon2641
            • Jun 2014
            • 10
            • United states
            i ordered the 399-5982-ND and it did not work The other part should be here tomorrow but if this one didnt work how do i figure the next one will? my led light is on and you can hear it make a noise when you plug it in this tv is only 3 yrs old what else could it possibly be??
            • whatusername
              • Dec 2013
              • 456
              the one I used was the 399 5982 and my TV came to life so you must have a different problem
              • whatusername
                • Dec 2013
                • 456
                the symptom sounds the same. .. red light on plus click but no response to touch sensor or remote... did it have a bulged blue capacitor? if so is that the one you replaced? Did you make sure to double check your soldering? all cables connected? it was a quik ez fix for me..
                • shannon2641
                  • Jun 2014
                  • 10
                  • United states
                  #28
                  • shannon2641
                    • Jun 2014
                    • 10
                    • United states
                    #29
                    sorry for the double post and yes i did all that but maybe the soldering needs to be done again cause there is still nothing
                    • shannon2641
                      • Jun 2014
                      • 10
                      • United states
                      #30
                      and no the blue thing wasnt bulged the repacement wasnt blue it was black??
                      • whatusername
                        • Dec 2013
                        • 456
                        when the blue cap fails its noticeably buldged on one end if its not then there's a good chance it did not fail and that is not your problem and yes the replacement is black... most of these tvs fail do to the blue cap.. but your seems to have a different issue
                        • shannon2641
                          • Jun 2014
                          • 10
                          • United states
                          #32
                          hopefully the pictures uploaded
                          • shannon2641
                            • Jun 2014
                            • 10
                            • United states
                            #33
                            im thinking so cause the blue cap is not bulged as you can see
                            • shannon2641
                              • Jun 2014
                              • 10
                              • United states
                              #34
                              none of the round things are leaking or bulged either sorry i dont know what they are called im not experienced in this kind of thing or you can blame it on me being a girl lol
                              • whatusername
                                • Dec 2013
                                • 456
                                lol those are capacitors too... well at this point you're going to have to open up the TV and start doing some testing on the boards hopefully you have a DMM so you can check all the outputs from the power supply
                                • shannon2641
                                  • Jun 2014
                                  • 10
                                  • United states
                                  #36
                                  a dmm what? lol no i dont have anything like that but i have a friend who does thanks for you help up to this point.
                                  • whatusername
                                    • Dec 2013
                                    • 456
                                    lol ok well yeah you would need some testing equipment to go further the only thing you can do right now it is to take good clear pictures of the chassis's and all the boards where we can read the numbers and post em up
                                    • shannon2641
                                      • Jun 2014
                                      • 10
                                      • United states
                                      #38
                                      ok well im headed over to my friends with the tv now so I will let you know what happens..btw.. what is a chassis??
                                      lol
                                      • whatusername
                                        • Dec 2013
                                        • 456
                                        when you first open up to TV and you step back and you look at it and you see all the boards sitting on that metal framing that metal framing is the chassis so step back take a look at it take a picture of it and then start taking close up pictures of the boards
                                        • MisterD
                                          • Oct 2012
                                          • 668
                                          I think one person here fixed theirs and the op didn't , possible that the EEPROM needs replaced.
