Another Samsung HP-T5064, Good Sound, No Picture
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Another Samsung HP-T5064, Good Sound, No Picture
    pics
      Well Vscan (Vsc) is measured across this blue capacitor.
      https://www.badcaps.net/forum/attach...0&d=1364334100
      Check that..
      • johnboy1313
        • Nov 2012
        • 1959
        Measuring across that cap overloads my meter.
        http://youtu.be/JScpojy4kZ0
        • retiredcaps
          • Apr 2010
          • 9271
          #44
          Set your multimeter to manual range (400V) and see if it can read the voltage. If not, time to get a new multimeter.
          https://cdn.badcaps-static.com/pdfs/...26b5d701fe.pdf
          --- begin sig file ---
          --- end sig file ---
            If the output is pulsing that will happen, the autoranger on the meter is too sensitive.
            • johnboy1313
              • Nov 2012
              • 1959
              That is a brand new multimeter. Less than a week old.
                Set your meter to a high DC range (400V/600V/1000V) using the range button. It'll stay locked in that range. Right now it is struggling to autorange as it receives the pulses from the power supply.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  Looks like I need to return this meter. I can turn off auto-range and set the meter to 000.0V and as soon as I touch the probes to the blue cap, "AUTO" pops back on and the meter goes crazy again. If I probe Vs at the connector, it stays locked.
                    Sounds like a bad design to me. While it might not be faulty, it's probably a bug in the controller, and it's not your problem to get fixed.
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      Got the Y-Main repaired and the set works. Now to try to find a base for this thing that doesn't cost more than the repair to the board.
                        How'd you repair the Y-main?
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          I bought a refurbished one via eBay. I'll get $50 when I send my old one in. Without being able to really identify the problem, I figured this was my best bet.
                            Can you see any obvious areas where repairs were made?
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              Yes, a few of the MOSFET's were replaced. Looks like a very good job.
                              • cadiman
                                • Mar 2010
                                • 397
                                #55
                                shorted mosfets will be the common issue with these.
                                A stand has been hard to find for these. I don`t know why.
                                I normally just weld up two legs that bolt to the back of the tv and paint it black.
                                I leave room under the tv for a cable box and / or dvd player.
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  It's like you're in my head. I've been looking ALL DAY for a stand. I've discovered that the stand from about 10 different models will work. I'm hoping to find one nearby with a broken screen for cheap. Maybe I can get the base and remote that I need and sell off the parts to get my $$$ back.
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    The money shot.
                                      Not bad! Another one fixed?
                                      • Mgiffune
                                        by Mgiffune
                                        06-09-2024, 10:28 AM
                                      • TR103
                                        by TR103
                                        - it keeps rebooting
                                        01-22-2025, 04:12 PM
                                      • Ierwin
                                        by Ierwin
                                        05-13-2025, 03:31 PM
                                      • jchang
                                        Samsung UN70NU6900F no picture and no sound
                                        by jchang
                                        Hi all
                                        I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                        Symptom:
                                        No picture no sound.
                                        When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                        No sound at all.
                                        What I tried:
                                        1. I tried unplugging the left or right ribbon...
                                        01-09-2023, 06:28 PM
                                      • Dodgethis
                                        Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                        by Dodgethis
                                        Hello all,
                                        This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                        09-11-2024, 07:39 AM
