I have a 42" Vizio TV. I get picture & sound but the picture is completely red. I changed the Y board the Z board and the main board but still no solution. Has anyone run into this problem? Any info will help. Thanks!
Vizio P42HDTV10A Completely Red Picture
Re: Vizio P42HDTV10A Completely Red Picture
Y and Z would never cause solid red picture. (Z may cause dim red or purple.)
However, a loose LVDS cable may cause this issue.
Can we have some pictures of the chassis?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by gavricHello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
When tv powers on vizio V logo shows nice on whole screen. picture 1
When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
When i start youtube picture shows on left side fine, right is all scrambled. pic 2
When i click video to start playing picture goes black(like when you change... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
- Loading...
