hi anyone can help me i have panasonic plasma her cannot change input video 1 when you selecting input video 1 canot see video 3 vga is ok.. i already try all setting even the hide menu setting but still same problem
panasonic plasma th-42pwd8 video 1 input not working
Tags: None
Re: panasonic plasma th-42pwd8 video 1 input not working
Can you try rewording the question a bit. It doesn't make much sense as it is and also can you post up pictures of the back of the TV?Comment
Try all inputs and report which ones are not working.
If I understand you correctly, you are saying that your scart sockets do not work but your pc input,vga, does.
Try all inputs, you'll probably find scarts do not work and nor do the component in, red yellow white inputs.
If you have hdmi on this model try that too, this will more than likely work.
The scart and component inputs require scaling by a processor whereas the hdmi and vga do not, so there is an issue on the main board, something you've probably already guessed.Comment
by jm1234Hi,
anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
I checked that board for any obvious faults... -
by stecosHi everyone!
For my passion for technology I'm now collecting several... -
by chazhThis is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,... -
by EaglecrestI have a 50" Panasonic that has a color stripe that shows up much of the time. See attached picture, what could cause this?1 Photo11-05-2025, 06:16 PM
by AlicatHello,
Stopped by this site trying to fix my parents Panasonic Plasma TV.
Model number is TH-50PZ85U
Power comes on and the red power light stays on solid.
Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
I also hear a few clicks.
I also think my parents said there was a thunderstorm and the TV failed after that.
Section 6 in the service manual talks about power and no screen,...10-30-2024, 10:09 AM - Loading...
