panasonic plasma th-42pwd8 video 1 input not working
  • exsonyexpert
    • Feb 2012
    • 20
    hi anyone can help me i have panasonic plasma her cannot change input video 1 when you selecting input video 1 canot see video 3 vga is ok.. i already try all setting even the hide menu setting but still same problem
  • exsonyexpert
    • Feb 2012
    • 20
    Re: panasonic plasma th-42pwd8 video 1 input not working
    up
    • martyparish
      • Dec 2012
      • 313
      Can you try rewording the question a bit. It doesn't make much sense as it is and also can you post up pictures of the back of the TV?
      • notallbad
        • Oct 2012
        • 1190
        Try all inputs and report which ones are not working.
        If I understand you correctly, you are saying that your scart sockets do not work but your pc input,vga, does.
        Try all inputs, you'll probably find scarts do not work and nor do the component in, red yellow white inputs.
        If you have hdmi on this model try that too, this will more than likely work.
        The scart and component inputs require scaling by a processor whereas the hdmi and vga do not, so there is an issue on the main board, something you've probably already guessed.
        • jm1234
          Panasonic plasma TX-P42ST50 - 6 blinks
          by jm1234
          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
          I checked that board for any obvious faults...
          05-22-2024, 06:59 AM
        • stecos
          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
          by stecos
          Hi everyone!
          I happened several times, in the search for help from the web, to consult this very interesting forum.
          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
          Having said that I come to the gist of my post on the forum as the title suggests.
          For my passion for technology I'm now collecting several...
          11-28-2022, 11:39 AM
        • chazh
          LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
          by chazh
          This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
          I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
          The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
          09-01-2025, 08:56 PM
        • Alicat
          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
          by Alicat
          Stopped by this site trying to fix my parents Panasonic Plasma TV.
          Model number is TH-50PZ85U
          Power comes on and the red power light stays on solid.
          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
          I also hear a few clicks.
          I also think my parents said there was a thunderstorm and the TV failed after that.
          Section 6 in the service manual talks about power and no screen,...
          10-30-2024, 10:09 AM
        • ugamazing
          820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
          by ugamazing
          So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
          1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
          2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
          04-10-2024, 08:06 AM
