50" LG plasma . Vertical lines up and down screen.
  • Vaughn.E
    • Mar 2013
    • 11
    I need help, I have sound but no picture. The vertical line are different colors and range in size. I have tried un-plugging, and check all hdmi hookups. I pulled the back panel off but i dont know what i am looking for.
    Re: 50" LG plasma . Vertical lines up and down screen.
    Without a picture, it's hard to judge. However, it is possible the panel is bad, which would be uneconomical to fix.
    • Vaughn.E
      • Mar 2013
      • 11
      YSUS panel? Could it be a fuse ?
      • Vaughn.E
        • Mar 2013
        • 11
        I have a Thomas blasters multimeter 109, is there any way to check?
          Plasma panel itself.
          Y-sus and Z-sus can never cause vertical lines.
          They are only responsible for making the whole screen light up.
          Please, we need pictures.
          • Vaughn.E
            • Mar 2013
            • 11
            oh i see. any way to check the plasma panel?
              Pictures. Pictures.
              Pictures please.
              • Vaughn.E
                • Mar 2013
                • 11
                Here is a pic, sorry it took so long... still learning how to do this..
                  Do those lines move across the display occasionally?
                  How's it look like with a menu or video on the screen at the same time?
                  • Vaughn.E
                    • Mar 2013
                    • 11
                    here is another. The TV now with shut off right after it goes to this screen.
                      Possibly Y buffers.
                      • Vaughn.E
                        • Mar 2013
                        • 11
                        The lines do change, when i change chanels of push menu.
                        • Vaughn.E
                          • Mar 2013
                          • 11
                          would this also cause the tv to turn off?
                            Y-buffers then.
                            I may have to retract Y-sus as "not being the cause"!
                            There is the possibility the Y-sus has damaged the buffer board.
                            Because of the cost of Y-sus and buffers it would most likely boil down to an IPM replacement plus replacement of up to 8 buffer ICs, which is not an easy job.
                            • Vaughn.E
                              • Mar 2013
                              • 11
                              where is the best place to order parts?
                                ShopJimmy, eBay, etc.
                                Be weary of eye-watering prices.
                                • Vaughn.E
                                  • Mar 2013
                                  • 11
                                  thank you very much!
                                  • Stanley1843
                                    by Stanley1843
                                    06-29-2024, 11:54 AM
                                  • Firentiosi
                                    1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                                    by Firentiosi
                                    Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                                    The issues are as follows: the...
                                    11-27-2024, 12:33 AM
                                  • Ancient1
                                    Strange LG TV issue : Image vertical lines in black screen
                                    by Ancient1
                                    Hi
                                    Asking for a friend.
                                    I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
                                    but here its the opposite !
                                    TV has new T-con = same issue
                                    A missing panel voltage would have global effect
                                    So , what should one do ? how can I find where the fault is ?
                                    Thanks !...
                                    02-05-2025, 03:37 PM
                                  • Kambi13
                                    Samsung LE32C530F1W with vertical lines on Screen
                                    by Kambi13
                                    Hello all, I'm dealing with a Samsung LE32C530F1W that now has vertical lines on the right side. It started with a ghost image on the top of the screen and then I tried the old trick of masking a few contacts in the flat cable that connects the T-Con board to the screen with some tape. It worked for a while and now out of the blue it turned into what you can see in the pic. I was able to get my hands on a known good T-Con board but the problem still persists. Now, what I've noticed is that the cooper colored flat cables that are directly connected to the screen itself are very hot to the touch...
                                    09-15-2022, 07:48 AM
                                  • ItalianSat
                                    LCD SAMSUNG LE40A656A1CXXE - Vertical Lines on Half of The Screen?
                                    by ItalianSat
                                    Hello Everybody,
                                    I have a 40 inch LCD SAMSUNG LE40A656A1CXXE. Its problem is that there are Vertical Lines on Right Half of The Screen.
                                    Interestingly enough, when I move my mouse (in the case if connected to a PC) or when I am watching the TV, lines also move. At first appearance, I had thought that the problem might arose from loose vertical ribbons (COF), but when I opened up the TV for further investigations, I realized that the problem cannot be solved by touching them.
                                    Moreover, I detached the T-CON board for a new round of investigation. I personally...
                                    06-28-2022, 06:02 AM
