After around four years, my Hisense HSL5529HDI LCD TV I was using as a computer monitor gave up the ghost yesterday. The reason? A row of Samxon GDs failed in the PSU, also taking out a "TLC" brand cap on the main board. This same TV lost its RF connector early in its life (2009) due to our cat tripping over the aerial cord and ripping it straight off the board, still connected to the cable. Ironically, the same cat also did this to our CRT TV in 2005 (a 51cm Dick Smith/"DSE" relabel).
Also of note, while the panel was 1680x1050, if you plugged a 1680x1050 VGA signal into it, it would truncate this to 1400x1050, stretching the result to 1680x1050. Yet, if you used a highly unusual 1440x1050 mode, you would get 1:1 pixels if you changed the TV's display mode to 4:3 (also, the 'wide' setting was called 16:9 according to the OSD itself). I never tried DVI with this PC (note that the TV would then require a DVI-HDMI adapter).
Capacitor specs/locations:
PSU board, JSI-220402/ROHS (that four-letter-word again)
C1: Samxon ZS 220uF 25V 105°C
C3: Samxon GD 470uF 25V 105°C
C11F: Samxon KM ???uF 420V 105°C (obscured by inductor)
C12F: Samxon KM 10uF ??V 105°C (obscured by mains filter cap)
C15F: Samxon GD 470uF 25V 105°C (bulged)
C16F: Samxon GD 470uF 25V 105°C (bulged)
C17F: Samxon GD 470uF 25V 105°C (bulged)
C18F: Samxon GD 470uF 25V 105°C
C22F: Samxon KM 1uF 50V 105°C
C29F: Samxon KM 47uF 25V 105°C
Main board, "Aoh" E303981, RSAG7.820.1536/ROH VER.D
CA2: Sancon CD110 470uF 16V 85°C
CA8: TF CD110 220uF 16V 85°C
CA9: Sancon CD110 470uF 16V 85°C
CA10: Sancon CD110 470uF 16V 85°C
CA36: TF CD110 220uF 16V 85°C
CA38: TF CD110 220uF 16V 85°C
CA46: Sancon CD110 470uF 16V 85°C
CA81: Sancon CD110 470uF 16V 85°C
CA83: Sancon CD110 470uF 16V 85°C
CA84: Sancon CD110 470uF 16V 85°C
CA86: Sancon CD110 470uF 16V 85°C
C691: TLC CD110X 680uF 16V 85°C (bulged)
C704: Sancon CD110 470uF 16V 85°C
C808: TLC CD110X 220uF 25V 85°C
Surface-mount poly caps are not mentioned (all are labeled 8i 100 16V).
