Goodmans LD3265D2
  • newtothis
    • Mar 2013
    • 1556
    • england
    Goodmans LD3265D2
    I have a faulty Goodmans LD3265D2 LCD TV that is powered by a dreaded VESTEL 17PW26-1 V1 PSU...
    My fault symptoms are as follows:
    Tv once in a million moons will power on fine (1 out of 2000)
    TV Mostly just flashes the blue LED without pattern
    Sometimes the TV will show a solid blue LED saying its in standby... when I try to power the unit up the backlight flashes briefly then goes back to the solid blue LED standby state.
    My knoweledge of electronics is basic but I have got into the TV and visually checked all caps and looked for any obvious cold solder joints but all look good.
    I am assuming it is a faulty PSU and have one on order but thought I'd get some opinions off you guys (especially tom) to see what you think.
    I also removed the driver board to PSU cable and plugged the tv in... The backlight flashes then goes off, flashes then goes off in a repeated pattern... If I short the BL_ON off pin 8 the backlight stops flashing.
    Any ideas?
    Re: Goodmans LD3265D2
    Replace two 15nF caps C877, C878.
    • newtothis
      • Mar 2013
      • 1556
      • england
      Hi tom thanks for the reply.
      I cannot find C877 and C878 is the rectangular component coded MMKP82?
        Can we see a picture of the chassis? It may be different...
        • ron77
          • Dec 2012
          • 63
          • united kingdom
          Tom it is different
          Ron 77
            I've worked on the LD3265 (no "D2") so I am wondering what the major differences are.
            • ron77
              • Dec 2012
              • 63
              • united kingdom
              Not your fault, confusion here, I believe. Flat tv parts have pics. Search for psu no, not model. Have researched it only for short time. Have new 17pw26-5 in front of me. Different psu. I do know where you are coming from though. Maybe I am wrong.
              • is_it_a_bird
                • Feb 2013
                • 59
                • United Kingdom
                Have a look at D893 it maybe labelled D881
                • ron77
                  • Dec 2012
                  • 63
                  • united kingdom
                  D893/d881 is common fault, usually goes s/c. There is some information on this psu, badcaps forum page 39, at this moment in time.
                  • is_it_a_bird
                    • Feb 2013
                    • 59
                    • United Kingdom
                    Just had a look back and from the last 4 I have done it was exactly that, only 2 where the fets had blown and that would give you different symptoms, out of the vestel range I do, dare I say it "like" the 26...easy money when that diode fails
                    • ron77
                      • Dec 2012
                      • 63
                      • united kingdom
                      The Goodmans ld3265d1 uses 17pw20 series psu. Goodmans model ld3265d2 uses 17pw26 series psu. They are completely different psu's. Your psu is newer and larger. Measures 22cm x 15cm. Last vestel tv I repaired, similar psu to yours was a Celcus. It was stuck in standby. Repaired it by replacing main board. As you have already ordered psu, you will soon find out if you got it right or not. I hope you are lucky. Ron77
                      • newtothis
                        • Mar 2013
                        • 1556
                        • england
                        Thanks for the replies guys...
                        Here is a picture tom...
                        So do my symptoms go towards the main board or PSU?
                        By the looks of the PSU it has been repaired and by checking it against schematics some of the caps are different ratings... The psu is also whining when live and clicks and buzzes. Dont know if that helps.
                        • newtothis
                          • Mar 2013
                          • 1556
                          • england
                          *bump*
                          • is_it_a_bird
                            • Feb 2013
                            • 59
                            • United Kingdom
                            When you say different ratings do you mean voltage or farads ie
                            Have they put 35v where 25v have been or have they put 220uf where 470uf's should go
                            • newtothis
                              • Mar 2013
                              • 1556
                              • england
                              one of the 470uf has been replaced with a 47uf cap... thats got to bugger things up right?
                              Also noticed a few other things.. looks like someone with no know how has done this board in an attempt at repair... Pin 2 of IC830 which according to the diagrams is the protection circuit has been severed :s
                              • newtothis
                                • Mar 2013
                                • 1556
                                • england
                                here is a pic of IC830... You can see the cut pin
                                • is_it_a_bird
                                  • Feb 2013
                                  • 59
                                  • United Kingdom
                                  Id change the cap straight away for the right one, Have you got a picture of the underside of the board? Has it blown the leg off the IC
                                  • is_it_a_bird
                                    • Feb 2013
                                    • 59
                                    • United Kingdom
                                    And is D893 OK?
                                    • newtothis
                                      • Mar 2013
                                      • 1556
                                      • england
                                      Dont think im gonna check anything else as to what i can tell its got to be the PSU that is indeed shot.
                                      Here is a pic of the reverse side and of the IC that indeed has a leg blown.
                                      Dont see any point in repairing it as have one on order and should be here tomorrow.
                                      Would you agree it is the PSU that is dead with all of that?
                                      • newtothis
                                        • Mar 2013
                                        • 1556
                                        • england
                                        Fitted replacement PSU today and TV booted first time with no issues.
                                        Thanks for any input off you
                                        • Egidio85
                                          Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
                                          by Egidio85
                                          Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
                                          the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
                                          the fan does not start.
                                          I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
                                          any advice on what to check?
                                          06-10-2025, 05:00 AM
                                        • cajoeg
                                          Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                          by cajoeg
                                          Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                          The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                          02-10-2025, 04:01 PM
                                          Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:50 AM
                                          Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-07-2024, 05:00 AM
                                          Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
