Sharp LC32D44E-BK Stuck in standby mode
    Re: Sharp LC32D44E-BK Stuck in standby mode
    The relay is very quiet on this model.
    • Jahson
      • May 2012
      • 245
      anything else you suggest i can try.
        Done the solder bridge in the video?
        Remove all of the screws on the power supply/inverter and clean them. They are the PSU's ground.
        • Jahson
          • May 2012
          • 245
          i try all that now, cant even get the service screen to flash for 1 second since ive done some re-capping?
            I have no idea. Frankly, why recap this? It uses top notch caps! Very well built! Rubycon, United Chemicon, Nichicon! Put the originals BACK. They are most likely better than the ones you used.
            • Jahson
              • May 2012
              • 245
              ok tom66 ive done the bridge on c7558 its stays on, the screen now says !Status Database Empty
                No freeview channels programmed then.
                And PLEASE put the original caps back for longevity.
                • Jahson
                  • May 2012
                  • 245
                  done the next step vol- & p-, i get to the screen with the orange writing, version,checksum, etc.
                  i cant move the yellow bar like how you select stuff.
                  • Jahson
                    • May 2012
                    • 245
                    ok will try re-install the caps later. the ones i did put in are very good brand.
                      What brand did you use?
                      Remote is necessary to navigate through the menu...
                      http://www.ebay.co.uk/sch/i.html?_od...emote&_sacat=0
                      • Jahson
                        • May 2012
                        • 245
                        do you think i most def need the remote control, also dont know whot i press but its gone to a next page saying pal+tuner adj ***Error***.
                        3/4 down the screen it looks like theirs a slight dim look, going across the screen.
                        • Jahson
                          • May 2012
                          • 245
                          i only recap like 3 1000uf 25v, & 2 22uf 50v, they are low esr, they aint crap.
                            Yes because you need the left/right arrow buttons. Leave the other option for now.
                            You have a bad bulb in the panel which is the original fault. This must be replaced. Bulbs are around £15 each for this model.
                            Which brand and series? Where'd you buy them?
                            • Jahson
                              • May 2012
                              • 245
                              so you saying get that remote control for £11.79 will be ok.
                                I can't guarantee what someone else sells, but you DO need a remote to access the service options.
                                • Jahson
                                  • May 2012
                                  • 245
                                  they are from HM COMP, ebay seller.
                                    BRAND and SERIES of capacitor, or link to the auction/buy it now page you bought them off.
                                    • Jahson
                                      • May 2012
                                      • 245
                                      That dimmish look 3/4 down the screen i can only see it, from here at my comps, like 3 meters away, but infront of screen you dont see it.
                                      ive press the input button an i can go thru to the channel selection menu, but it seems its tune to a satalite.
                                      Do you know if it has freeview built in?
                                        Yes, it has freeview built in.
                                        You need the remote for almost all of the features on this unit.
                                        Also, please link me to the page where you bought the caps.
                                        • Jahson
                                          • May 2012
                                          • 245
                                          i had to go into my ebay archive, i got them from semtech1
                                          http://stores.ebay.co.uk/componentspares
                                          think they panasonics fm series
                                          • lepak06
                                            TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                            by lepak06
                                            Hello
                                            I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                            The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                            Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                            All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                            But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                            01-12-2023, 01:43 AM
                                          • lego1234567
                                            LG 32LB1R - stuck in standby mode
                                            by lego1234567
                                            Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                            What could be the problem ? Thanks...
                                            01-21-2024, 03:39 AM
                                          • modtool
                                            HP x360 Chromebook 14A-CA, DA00GIMB6H0 REV:H, flooded, restored, slow and stuck in tablet mode
                                            by modtool
                                            Dear colleagues,
                                            I've entered the repair of the chromebook machines just one month ago and I've found some significant differences from the classic laptops or macbooks, so I'm searching some advices.
                                            The owner of this chromebook gave it to me after it has been left flooded by water for almost a week, so chances of repair were not so high, the mainboard was oxidyzed in many spots but I made a nice cleaning, resoldering and component replaging work and now it is almost working.
                                            Among other things I've cleaned many spots from oxyds, reballed CPU, EMMC, EC, replaced...
                                            05-07-2025, 06:10 AM
                                          • YellowJacket
                                            SHARP LC-32CHF5111K - stuck at color test mode
                                            by YellowJacket
                                            Hi friends,
                                            TV has stuck at - as I googled the term - color test mode. Slowly flashing colors white, red, green, blue, black, over and over again. I tried some hints from internet, like pressing some remote buttons, but nothing worked. I also tried factory reset for Sharp TVs => "while holding vol– & input buttons on tv plug in set when “k” appears push vol– & chan- " , but TV doesn't even start during buttons pressed.
                                            So I decided to flash new firmware to SPI ROM. What do you say, would it help? If so, where can I find some dump? I was unable to find...
                                            02-04-2023, 03:11 AM
                                          • The_Memory_Guy
                                            Dell T7820 stuck in Bios Recovery Mode
                                            by The_Memory_Guy
                                            HI,
                                            I have a Dell T7820 stuck in Bios recovery mode. I never get Dell Boot screen or anything visible on screen. The system just gives me 3 white lights and 3 orange lights indicating Bios recovery mode.
                                            What I have tried to get to recover the Bios, there seems to be some conflicting advice about recovering the system.
                                            All of them say to download the latest bios from the dell website which is a .exe file. I have done that
                                            https://www.dell.com/support/product...BUT090/drivers
                                            Some...
                                            07-07-2025, 06:52 AM
