Samsung LE32R87BDX
  • anotherdude
    • Feb 2013
    • 488
    Samsung LE32R87BDX
    Replaced all the bulging caps on this tv's power board due to it not turning on, replaced the caps all seemed fine until i plug a device into the tv.
    If i connect a hdmi or scart device to the tv there is sound distortion and picture distortion, if i turn it on with the device connected the tv reboots itself around 6 times before eventually everything clears up and the tv works as normal.
    Been reading and reading and it seems the main board is at fault
    any clues?
  • cashkennedy
    • Aug 2011
    • 668
    Re: Samsung LE32R87BDX
    I would recomend either testing (with an esr meter) or replacing the rest of the capacitors on the power board first, If that doesnt fix it, then likely a main board issue. Have you tested all the voltages leaving the power board with a volt meter? Does blowing hot air at either board make the problem go away faster?
    Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
    • anotherdude
      • Feb 2013
      • 488
      no esr meter to test, theres only 1 large capacitor i haven't replaced
      just tried a factory reset but didn't help, could it just be age power on time is 21143 hours
      if i've had the tv on for the first few minutes and then turn it off for 10 minutes then back on the symptomns are not as bad, theres no restarting or bad sound but the picture remains distorted for a few more seconds then clears up
      to me it seems like something is simply warming up or voltage isn't being regulated correctly
      not tested the voltages yet, how am i supposed to know what they are ment to be?
      there seems to be a lot of gunk around certain parts on the power board i know some of it looks normal (it's on similar components) but some not so much will get a picture later today
      • anotherdude
        • Feb 2013
        • 488
        see the mosfet on this board looks damaged, but not got the tools to test
        • anotherdude
          • Feb 2013
          • 488
          so i removed the glue from around the mosfet after reading about the glue being conductive when it turns brown, it was hollow and it looks like it's ate away at the mosfet legs
          need changing?
            Those "SD" capacitors are NOT suitable for a switching power supply! Let me guess... Rapid Electronics? eBay? I use Panasonic and Rubycon which are rated for SMPS use due to their low ESR.
            • anotherdude
              • Feb 2013
              • 488
              actually what it was that maplin didn't have a replacement 10v and i originally had a 25v one in there (not sd and rated at 105c) same uf rating but got the same issue with this 1 too so guess thats not the issue
              or am i wrong to assume that the voltage doesnt matter on caps and that the uf rating is important?
              also the brown mosfet seems to have no continuity in circuit whereas others do
              the mosfet/transistor thats dead i can't find anywhere cheap enough for it the original is 512-KSD526Y
              and these are the replacments i can find but there £10 for postage no idea if i'm even on the right track here but it seems dead
              863-BD442 512-KSD526Y 512-KSD1408YTU
              • Foppel
                • 62
                Have you tried to resoldering and cleaning the glued Transistor QB802? You can use Isopropanol to clean the Transistor. See: https://www.badcaps.net/forum/showthread.php?t=22470 Maybe you can use a heat gun (or hair dryer) and Cooling Spray to locate the faulty parts.
                schematic: https://cdn.badcaps-static.com/pdfs/...b225f06d1f.pdf
                Please give us a picture of the bottom side of the board. Maybe we have bad soldering spots.
                  The capacitance is most important.
                  Voltage should be the same or higher except in very particular circumstances.
                  • anotherdude
                    • Feb 2013
                    • 488
                    not got pictures of the underside atm but shouldn't there still be continuity from the transistor i've removed all the glue and my multimeter on other transistors on the board has conituity in circuit, this does not also does not out of circuit, if theres no continuity doesn't that mean the part is bad?
                    i followed this http://www.decibelcar.com/menuelectro/93.html and there is no continuity at any point
                    seem i might of put too much heat on one of the legs when removing the transistor it's left copper exposed other than that my soldering looks fine i think
                    anyone know where i can get a new transistor at a reasonable price and not £11 or anyone have one laying about? it's a d526-y
                    any reason that a possible dead transistor could cause the problems i'm having?
                    • anotherdude
                      • Feb 2013
                      • 488
                      so i've gave up on that transistor doesn't seem to be the issue, i removed it and powered the tv on and i get nothing, guessing if it was at fault i'd get the same thing
                      anyway left the tv off for 10-15 minutes after putting the transistor back in and left it to cool
                      switched it back on and got the same thing again so got the hairdryer on the main av board and after maybe 10-20 seconds the picture clears up
                      a reflow in order maybe?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        can you pin point the exact area the heat affects it?
                        • anotherdude
                          • Feb 2013
                          • 488
                          i will after liverpool win
                          • anotherdude
                            • Feb 2013
                            • 488
                            so just got a chance to test it again and found it's this area i heat here for 5-10 seconds and the tv only reboots once and the picture and sound are fine
                            this was just with a hair dryer, i do own a heatgun if people think it's needed
                            • Foppel
                              • 62
                              Hey Dude. I think it's not easy to remove the cover. But you can check the soldering spots. But sometimes the BGA chips lose the contact with the board and this is really hard to fix I tried to fix a bga processor from an Nintendo DS with a reflow soldering station. But i use too much heat and the CPU died ;( Good luck
                              • kevinm34232
                                • May 2012
                                • 1884
                                Can someone point to a thread on how to safely reflow a TV main board in an oven? I think Ill need to do one aswell..
                                • anotherdude
                                  • Feb 2013
                                  • 488
                                  i don't think this is to the same degree as a hair dryer doesn't create that much heat with 10 seconds i'll take the board off the tv later and see if theres anything obvious, hoping for a cold joint
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    or a bad capacitor under the Shield how easy it to unsolder the lid/top
                                    • anotherdude
                                      • Feb 2013
                                      • 488
                                      ye i thought that too, took the shield off and theres nothing visible to say there bad
                                      any help?
                                      • Foppel
                                        • 62
                                        You can check the caps with an ESR Meter but i think they are ok. You can carefully press with your finger on the BGA Chips and then you can see if its a bad contact.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
                                        • ermals
                                          Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                                          by ermals
                                          Hi all!
                                          I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                                          1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                                          2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                                          3. I've checked voltages...
                                          08-01-2022, 10:35 AM
                                          09-07-2024, 05:50 AM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
