Yes another Sanyo DP42849 Backlight
  • KJINTF
    • Dec 2011
    • 22
    • usa
    After looking over the several other Sanyo DP42840 threads
    I was not able to find any resolution to the backlight issue
    My Sanyo backlight flashes for less than one second after the turn on process
    As far as I can tell all the other functions work OK - Audio and video seem to be fine - Just no backlight
    To date I removed the CCFL connections inserted a new good lamp with exactly the same symptoms, All voltages BLon, Stby 5v, 12v, etc mesure fine
    Have others found that the single inverter transformer itself is the problem?
    None of the other posts had any resolutions - Looking forward to hearing from others with a fix for the issue
    Thanks for the help
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • DanPoka
    by DanPoka
    02-15-2025, 05:05 AM
  • Comp_Pro
    No Backlight Macbook A1990 820-01041
    by Comp_Pro
    Hello all,
    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
    Tests performed:
    There is no backlight even with a good screen.
    Backlight IC is receiving the correct support voltages.
    Fuse F8400 ok
    Current sense resistor R8400 ok
    Backlight IC is receiving 3.3V on enable pin.
    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
    Backlight IC receiving 5V from PP5V_G3S
    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
    05-06-2024, 10:23 PM
  • cheebster
    iPad Pro 12.9 5th Gen Backlight Issue
    by cheebster
    Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
    Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
    Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
    The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
    Anyone...
    05-20-2025, 09:17 AM
  • canadaboy25
    LG Flatron 24EN33TA No Backlight When Cold
    by canadaboy25
    I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
    I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
    03-07-2023, 12:23 AM
