TOSHIBA 46RV555DB No picture but sound back light is on
+ More Options
Posts
    Re: TOSHIBA 46RV555DB No picture but sound back light is on
    Sounds like a cold joint or some problem on main board where connector goes... try lightly pressing around the area to see if it occurs again.
    • Andyd1970
      • Feb 2013
      • 374
      • united kingdom
      #42
      Hi Tom,
      I have tried another main PCB and the syptoms are the same, I have refitted the original main PCB, can you please explain a bit more what you mean and where you mean on the PCB's.
      Andy
        How many boards do you have? If you have that many PCBs, swap every one out until it works!! That appears to be the way of most TV techs these days -- no diagnosis, just swap boards til it works...
        • Andyd1970
          • Feb 2013
          • 374
          • united kingdom
          #44
          Hi Tom66,
          I just have a replacement main PCB as in earlier posts to my thread it was suggested it could be main PCB. So with either the original main PCB or the replacment main PCB I get the same results, no picture, back lights on and sound OK. I'm like you I dont like just swapping PCB's as that isnt fault finding. Currently I just have the two connectors that go from the 100Hz PCB un-plugged from the T-Con PCB and I get backlight and the relay on the PSU does not tick.
          Andy
            Makes me think of a problem on 100Hz or T-con, but I'm not sure which.
            • Andyd1970
              • Feb 2013
              • 374
              • united kingdom
              #46
              OK, thank you, I will try to see if I can buy a T-Con first, do you know of good TV part suppliers?
              Andy.
              PS - Thank you again for all your help.
                flattvparts.co.uk I have used before.
                • dronerat
                  Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                  by dronerat
                  Hi Guys,
                  This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                  PSU: L48S6 FHS BN44-00807D
                  T-Con: BN95-01937A
                  Panel: CY-GJ048HGLVLH
                  MB: NA (Currently as the TV is assembled and forgot to take picture)
                  As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                  It was sent to an authorized service for repairs and returned with the...
                  05-15-2020, 08:03 AM
                • koby058
                  vostro comes up with back light but no picture
                  by koby058
                  Hi people!!
                  The owner said it showed bad picture once in a while (attached)
                  I see that there is back light but no picture.
                  I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                  Also attached schematic and BDV
                  LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                  Yesterday, 01:03 PM
                • kca
                  Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                  by kca
                  Hello all ~
                  I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                  This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                  No picture. No sound.
                  I tested all the voltages coming out of the power supply...
                  10-12-2023, 05:23 PM
                  Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                  This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                  I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                  I am comparing them to a brand new one that I installed
                  The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                  I going to let it run for several days before I remount back on the wall next to the...
                  09-05-2024, 06:48 PM
                • slimsoul
                  Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
                  by slimsoul
                  Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
                  I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
                  I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
                  The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
                  03-12-2024, 03:55 AM
