Panasonic TH42-PZ80U - SS board or Panel?
  • coolie121
    • Feb 2013
    • 11
    Re: Panasonic TH42-PZ80U - SS board or Panel?
    Scratch my last post. I stood behind it and waited. didn't take too long. The shut off interval seems to be getting successively shorter today. First 45 minutes, then 10, then 5, now 2.
    The reading on TPSOS8 spiked as the TV shut off. It went from 0.02V to 23.6V
    And the measurements in the previous post were made 30 seconds after the blinking started. It took me some time to get the multimeter and get in place.
      23V is quite high? Was that DC or AC?
      But anyway, this indicates the SS or Panel is defective. I'd be more inclined to think SS, because I've not heard of an intermittent panel. I would try heating SS with hot air and seeing if it cuts off quicker.
      • coolie121
        • Feb 2013
        • 11
        DC voltage
        This is strange. I changed the SS-board last week. I guess this means that my replacement from shopjimmy may have been dead on arrival . I will need to call them tomorrow.
        By the way, what can cause a panel to go bad? And is there any way to fix them?
          Since you changed the SS, I would be more considering the panel then... though I just had a thought. If the D board stops sending signals to the SS, it can cause erroneous 8 blink codes. I have heard of this issue before, with the SC and erroneous 6/7 blink codes.
          In terms of panel failure, this series of panels had a minor issue with contamination. It was (I think) Panasonic's 2nd or 3rd generation 1080p 42" plasma panel, which is a major process upgrade from doing 37"/42" 1024x768 panels and WVGA 853x480 ones. Some dirt or stray material gets trapped and migrates somehow, causing a shorted panel (SCn to SS electrode short.) As far as repairing it, I don't know -- but it might be possible to "blow out" a short by using a fairly high current. No idea if this would cause other damage though. And herein lies my confusion. If the panel was shorted, it should just not work at all. I don't know why it would be thermally sensitive, which is why I am considering the D board more or perhaps the A board.
          Really the only way to be sure is start heating up stuff...
          • coolie121
            • Feb 2013
            • 11
            Then it looks like I'll be using the hair dryer this weekend when I've got time to tinker with the boards. I'll keep you posted. Thanks for the help so far everyone, I appreciate it.
            • Andre Gilbert
              by Andre Gilbert
              11-20-2024, 08:52 PM
            • AquaMan Ua
              Problem with PANASONIC CF53 laptop after changing BIOS settings
              by AquaMan Ua
              Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
              05-17-2025, 09:40 AM
            • stecos
              Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
              by stecos
              Hi everyone!
              I happened several times, in the search for help from the web, to consult this very interesting forum.
              So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
              Having said that I come to the gist of my post on the forum as the title suggests.
              For my passion for technology I'm now collecting several...
              11-28-2022, 11:39 AM
            • aa10aa10
              Panasonic Toughbook CF-33 mk1 BIOS repair
              by aa10aa10
              Good day,
              I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
              I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
              01-21-2025, 06:13 AM
            • Mnawar27
              Panasonic CF-H2AU24EF3 bios locked
              by Mnawar27
              Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
              I need help to remove it,
              thankyou all.
              SN; 2FKCA26876...
              11-16-2024, 08:00 AM
