55LD520 backlighting issue?
  • cashkennedy
    • Aug 2011
    • 668
    This is listed on my local craigslist
    http://batonrouge.craigslist.org/ele/3613072694.html
    I asked the seller what model it is and he said it was a 55LD520-ua
    I would never pay 300 for it, but im considering offering ~120-150 for it.
    The "obvious" suspect would be that the slave inverter failed, but the seller says the set runs fine in this state for long periods of time, and you would expect the inverters to detect that much of a failure and send an error message. I dont know if its possible to have the main fuse on the slave/ or master inverter to fail and then not be able to even send the error signal?
    The inverters are dirt cheap for this model on ebay, but there are 2 versions it seems, one being very simple and only using 2 transformers per inverter, and the other seemingly having 1 inverter for every 2-4 bulbs.
    What would yall offer?
    Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
    Re: 55LD520 backlighting issue?
    It's a bad panel, in my opinion. If the slave inverter failed, the lighting cut-off wouldn't be so even.
    • cashkennedy
      • Aug 2011
      • 668
      I was somewhat worried about that too, cause the second picture shows some ghosting (could be from a slow camera) and shows some light getting through evenly on the bad side.
      The person didnt seem willing to budge much from the 300 (would only go to 260) so im not worried, just gonna ignore this one.
      • jimboh
        • Aug 2014
        • United States of America
        Sorry for hijacking this thread but I am hoping to get some help with my LG 55LD520 LCD TV which decided to take a break today. Here's what's going on:
        I was having an issue with the set getting a signal from my Comcast cable box earlier today. I actually had this same issue about two months ago, replaced the box and everything worked great until today. I know it seemed odd to be having the same exact problem with Comcast's equipment again, but I went ahead and got them to replace the box again which restored my picture. This fix lasted for all of about 30 minutes when the screen went black (still lit) with the LG logo + "No Signal" displaying. The no signal message lasted for about 30-60 seconds at which time the screen went dead (not lit, TV still on) before flickering faintly for around 30 seconds or so. Once the flickering stopped the screen stayed pitch black and the set was acting unresponsive when I attempted to turn it off using the remote until it actually turned off about 20 seconds after hitting the power button. I disconnected + reconnected all cables (power included) going to the set but it made no difference. At this time the only action I can get from the TV is the status indicator changing from red to blue and vice versa when hitting the power button.
        Do these symptoms sound familiar to anyone? If so, is there a suggested fix? Any help or links to relevant threads would be appreciated.
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          🛠 Original Issue
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • ugamazing
          by ugamazing
          12-17-2024, 07:05 PM
        • eccerr0r
          inverter H tree driver imbalance in an AC inverter
          by eccerr0r
          My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
          11-16-2025, 12:34 PM
        • Dreadnought
          L40DIGB20 Logik 40" inverter/backlight issue.
          by Dreadnought
          Hi. Firstly I apologise if I break any forum unwritten rules, as I'm new here. I've used badcaps for advice in the past, but I've only just joined. I'm self taught, so I don't have anywhere near the knowledge that some of you guys have, but I can only hope to keep learning and get there one day.
          Anyway, I've been working on a TV recently. It's the one listed in the title. Logik L40DIGB20. It powers on fine, with the standby light turning blue as it should. The backlight turns on for a second, then goes off. Using a flashlight, I can see an image on the screen. The power supply is fine,...
          02-08-2021, 12:28 PM
        • shahnld
          Lenovo legion 5 pro startup issue
          by shahnld
          Good day Experts
          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
          08-24-2025, 12:31 PM
