Polaroid TDA-03211C No Video
  • crdz66
    • Nov 2012
    • 242
    Hello Fellas.
    I have a Polaroid TDA-03211C with video problems.
    After the power on the Tv, Polaroid Message and Backlight turn on, but after 2 to 3 sec later turn off.
    I know is very common problem on this tv, but mostly point to capacitors.
    But, I desoldering and check one by one out to the board and everything is fine. Blue Meter and Capacitance.
    Do you thing the cause can be a bad lamp send me the signal turn off the backlight? The Tv keeps on (Blue light indicator).
    Any ideas.
    Thanks for looking
  • drpj23
    • May 2012
    • 528
    Re: Polaroid TDA-03211C No Video
    Do you have a visual? (you will need a source of light)
    How are your voltages looking from the psu and is there a BL_ON signal?
    Pics will help on this too.
      This one is also known for two bad caps (10uf 450V) for the inverter circuit.
      http://s807.photobucket.com/albums/y...cpZZ1QQtppZZ20
      You might as well replace the caps as a set.
      • crdz66
        • Nov 2012
        • 242
        The power board supply the next voltages
        5.01v
        12.1v
        23.45v
        according with printed, need to be 5v,12v,20v.
        Bk_on give me 4.4v
        Login:
        1 sec : black screen
        2 sec : black screen
        3 sec : backlight on and polaroid message on
        4 sec : turn black screen and 2 of 10 times show me blue screen and the rest black screen
        Comments.
        The Tv remains on (blue light indicator)
        Solid red light on power board.
        I check by induction the top of 2 transformers and when the backlight is on show me value and after backlight is off the value going down.
          How about the pictures of your board?
          • crdz66
            • Nov 2012
            • 242
            let me do that and post it.
            • crdz66
              • Nov 2012
              • 242
              Here we are the pics.
              • bl@ckh3art
                • Apr 2013
                • 4
                • united states
                I am having the same problem. I change the capacitor on the main power board and the lil red light on the corner keeps blinking. But blue light on the tv say on. The dvd player works fine. I put a dvd in there and it runs. But no sound or nothing. What should I do?
                • bl@ckh3art
                  • Apr 2013
                  • 4
                  • united states
                  The red light on the man power board blinks every two seconds. is there something I should Do? No sound or or video. any information will help thank you
                  • bl@ckh3art
                    • Apr 2013
                    • 4
                    • united states
                    Do you think it could be the back light of the tv thats blown? or just the video board thats bad.
                      A blinking light on that PSU does indicate backlight fault.
                      • bl@ckh3art
                        • Apr 2013
                        • 4
                        • united states
                        could it be caused by a cold solder that can cause that to blink. I was thinking about buying the whole thing on a website. But I wanted to see if i figure it out on my own. Sad part is the tv is kicking my butt. lol
                        • markatlantic
                          • May 2011
                          • 3
                          Question on Polaroid TDA-03211C
                          No pic, No sound, can anyone tell me the part no. for the D10 ? Also on the bottom of the board R16 is fried; looks like a 100 ohm value - is that correct. In advance, thank you for any provided
                          • markatlantic
                            • May 2011
                            • 3
                            No pic, No sound, can anyone tell me the part no. for the D10 ? Also on the bottom of the board R16 is fried; looks like a 100 ohm value - is that correct. In advance, thank you for any provided. Sorry - should have mentioned the board is IPOS 150 REV:1.8 2006.11.25
                            • MagicSmoke
                              • Feb 2011
                              • 275
                              You will have to change the 2 450v caps. I replaced every other cap on the one I have and it would not work until I changed the 2 450v ones.
                              crdz66 did you pull all of the caps under the heatsinks and check them?
                              markatlantic You will get more help by posting your problem in a new thread instead of jumping on someone else's thread.
                              • markatlantic
                                • May 2011
                                • 3
                                Thank you MagicSmoke. This is my first time posting to a blog and I thought I was suppose to put the problem under a heading that existed - if one was already started. Those caps look fine - but I will replace.
                                • MagicSmoke
                                  • Feb 2011
                                  • 275
                                  Mine looked fine also, no leaking or bulged tops. But pulled them to test, one 22uf 450v cap read 1.8uf the other would not read. both were bad.
                                    Bad caps can look normal.
                                      HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                      This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                      09-12-2024, 02:00 PM
                                      Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                      09-07-2024, 05:00 AM
                                      Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                      Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                      Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
