Lg plasma problem please help
  • Techhelp79
    • Feb 2013
    • Usa
    Hello all, I have an lg 50pk550 plasma tv. It's worked
    Fine for about 2 years now. A couple days ago, I tried to turn
    It on and it clicked, the screen lit up and it looked like it was
    Going to turn on like normal but then it clicked and shut
    Off. After a few seconds it clicked again and tried to turn on again
    All on its own. I removed the back panel and could not see
    Anything obvious (no blown caps, resistors, fuses etc).
    I grabbed my meter and began checking voltages and this is
    Where I would like to pick someone's brain with some expertise
    Working on these tvs. One interesting thing I want to point
    Out is that now whenever I plug in the ac to the wall, the tv
    Clicks and tries to turn on without pressing the on button. Any
    Ideas? I was able to find a place that carries this model power
    Supply but I'm not so sure this is my problem.
  • Rack
    • 12
    Re: Lg plasma problem please help
    If I remember the jist of this block of videos:
    http://www.youtube.com/channel/UCPCE...sort=dd&view=0
    one or both of the power resistors in the upper right-hand corner (when it's installed in the TV) of the power board start to head south, I think they were 22 ohm and rated for 5 watts. That would be my first check.
    That in turn can possibly cause a 6-pin voltage regulator, a diode near that regulator and fuse near them to all give up the ghost. That would be next.
    • Techhelp79
      • Feb 2013
      • Usa
      I really appreciate your help and advice! I was leaning towards just replacing the entire power supply but I got thrown off because of how the tv tries to turn on simply by plugging it into the wall. I found some schematics for this and it seems like the power supply gets a standby signal (ground) from the main processor. If this ground is floating (missing) it will automatically try to boot up when plugged in. And this is what it's doin? So I thought that maybe the main processor pcb is bad but I'm not sure?
        I know of several TVs (indeed, most) that will attempt to power on immediately after power is removed. If the TV had a problem perhaps this is what occurred and it is just trying to resume power?
        • robazorn
          • Jul 2014
          • usa
          I have this model tv and it doesnt power on, just clicks then red light comes on and i push it again, it clicks then the red light fades.
          i have this particular tv with the psu board number
          EAX61392501/8
          i checked the big white resistors and all 3 have the 10ohm resistance. the diode located by the resistor and voltage regulator is giving me straight continuity both ways.
          am i to assume that because this diode is bad , that the voltage regulator is bad as well?
          thanks
          • masoksian
            Dell latitude e7470 not turn on .power buton on off and Run Power problem
            by masoksian
            I am dealing with the problem of turning on and off my Dell e7470 notebook.
            The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
            The system does not turn on, there is no post.
            I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
            The problem continues in the same way.
            I tried to turn on the Fn key, nothing came to the screen....
            02-15-2025, 12:08 PM
          • PacoGT
            HELP!! Dell E6440 laptop with problem does not turn off and turn itself on help
            by PacoGT
            A few days ago my laptop gave me problems, when I wanted to turn it on to my surprise without charging so I did not put much importance on it, after that I turned it on with a charger, it turned on and charged the laptop, the problem with the laptop is that when it is turned off it turns to turn on after seconds, sometimes at 2 or sometimes at 8, other than that it works normally, I already checked many things, I changed a mosfet at the charge input to a pnp but it remained the same, after that I checked and I did not find anything outside Normally, before that, it had a failure where I changed...
            07-11-2023, 09:31 PM
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • matpod16
            Pioneer VSX-D1011 - turn on problem
            by matpod16
            Hi all! I have a problem with Pioneer VSX-D1011 – it don't turn on when the amplifier is disconnected from the socket for a few minutes. Standby LED doesn't light up. I'm a beginner in electronics, so I'm not very good at reading schematics. I tried to find the visual damages of components but I didn't see anything wrong. All of the fuses are ok, both of the switches the same. Have you any idea where should I start looking for? Once on every 100 tries I am able to turn it on, but what can it depend on?
            09-07-2023, 01:43 PM
          • pajdek
            Lenovo Y700-17ISK turn on and off
            by pajdek
            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
            09-20-2023, 02:49 AM
