Vizio e321vl u18 chip pinouts
  • iph0nespark
    • 14
    Hey guys I went on my own replacing the epprom however when I was soldering the epprom one of the connections came off and I was wondering If I could run a jumper to it. When looking at the board it's third pin going from left to right on the side of the chip with the recessed dot. Please help me so I can get it working. Btw I know I need the epprom because I tested it before soldering and it worked and when I went to solder it the connection came off
  • randtek
    • Oct 2011
    • 280
    • US
    Re: Vizio e321vl u18 chip pinouts
    Post a good close up photo of the damaged area of the board. We can try to see where you can run a jumper to.
    • iph0nespark
      • 14
      I saw the 3 spots where it could have been connected to but i didnt know which one
        You have damaged more than one pad there, by the looks of it.
        • iph0nespark
          • 14
          yes i did but i ran a jumper to that one. I just need to figure out which one do i put to that circled pin
            What's the part# for U18?
            • iph0nespark
              • 14
              I believe this is it MX25L6406E. I would greatly appreciate it if someone could use an ohm meter and find where that trace leads to so I can solder a jumper to it
                I will check the datasheet and get back to you.
                  Pin 3 may be connected to the ground (pin 4) if you do not require the TV to be able to update its firmware through the user interface or service port.
                  • iph0nespark
                    • 14
                    Why would I need to? And this will make.it work right
                    • iph0nespark
                      • 14
                      How do I know the pin number? What number is the one I have circled?
                        pin 1 is marked with a dot, then count right, when you reach the end of one side, count from the same end of one side backwards.
                        e.g.
                        8 7 6 5
                        1 2 3 4
                        • iph0nespark
                          • 14
                          Also there on the opposite site of the one circled when you look at the picture the first 2 pins on the left are bridged somewhere but not by the pads i checked are they suppose to be?
                            A bridge between #1 and #2 does not make sense...
                            • iph0nespark
                              • 14
                              I mean 8 and 7
                                That makes sense. Both go to Vcc, or the supply voltage for the chip, which disables it's HOLD feature.
                                • iph0nespark
                                  • 14
                                  So it should work fine with pin 3 and 4 connected?
                                    Yes, IF the pad is definitely destroyed.
                                    • iph0nespark
                                      • 14
                                      It is it completely came off
                                        OK, then that is fine.
