Vizio e321vl u18 chip pinouts
  • iph0nespark
    • 14
    Re: Vizio e321vl u18 chip pinouts
    Thanks ill try it now
    • iph0nespark
      • 14
      It works but ill update in a little while after testing
        Great so the TV's fixed?
        • iph0nespark
          • 14
          I do believe so its been on ever since. Ive been shutting it off and on every half an hour to be sure, Thanks for your help I appreciate it.
            Nice. Another item saved from the trash.
            • RicRus
              • Feb 2013
              • US
              #26
              I need help troubleshooting a Sharp 46'' LCD, Model LC4643U , will not power up, power light blinks once then the power and OPC light flashes once then repeats. I have taken the back off and can see no physical damage with caps on power supply. If I disconnect the power lead to inverter board #2 the unit will power up, I have sound and can change stations just no picture
                What relevance has this to a 32" Vizio?
                Put your query in a new thread please.
                • RicRus
                  • Feb 2013
                  • US
                  #28
                  Sorry I'm new to this forum thing. Where do I go to start a new thread?
                  • martyparish
                    • Dec 2012
                    • 313
                    Right here ric https://www.badcaps.net/forum/newthr...newthread&f=31
                    • iph0nespark
                      • 14
                      It looks good so far I thinks its a permanent fix. I am thankful for your help tom.
                      • acedogblast
                        by acedogblast
                        11-02-2024, 05:13 PM
                        Common SPI bios chip programming Questions and Answers
                        by SMDFlea
                        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                        A: If you can`t read from it how do you expect to write to it ?.
                        Q: Why is my bios chip unreadable ?.
                        A: The programmer is faulty or has a worn or broken zif socket.
                        The USB cable is frayed,connector pins worn or some other physical damage.
                        Not enough amperage or voltage to power the programmer properly.
                        Bad...
                        09-02-2021, 04:40 PM
                      • BMCappelletti
                        Asus Chromebox CN62 - wrong chip put on BIOS reader
                        by BMCappelletti
                        Long story short:
                        - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                        - gave the computer to his son a couple years later
                        - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                        - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                        (seems like the story was not that short)
                        He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                        01-08-2025, 07:27 PM
                      • Troystain
                        Help EZP2023+ updated chip database for w25q256jveq?
                        by Troystain
                        Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                        I need to add w25q256jveq chip but I do not know what data should I type.
                        I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                        The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                        11-25-2024, 12:53 AM
                      • inck243
                        Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                        by inck243
                        Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                        The BIOS...
                        07-25-2024, 09:17 AM
