lg 42px5d wierd screen problem
  • steve2k34
    • 36
    • uk
    i have this lg lg 42px5d and it has some wierd screen problem its al black and a slight picture in the corner but tv all works fine with sound if i can navigate in the menu to the ism menu then click white wash the screen all lights up but if you turn it of it slowly fades back to black has anyone had or know what this problem could be
    its as if the screen is very slow at firing
  • steve2k34
    • 36
    • uk
    Re: lg 42px5d wierd screen problem
    found a bad fuse on z sustain will let you's no on my findings its this fuse thats gone e.t4ah250vp
    is this the right fuse to get before i buy it http://www.amazon.co.uk/gp/product/B..._i=e.t4ah250vp
      I had one of these sets before when it was simply dust on the Y-sustain causing the issue.
      • steve2k34
        • 36
        • uk
        ive cleaned this set up as it was really thick with dust, had to change caps on power board as they were bulging this fuse is blown so hopefully when i get a new fuse it will work ok do you think maplins will stock these fuses
          Yes, maplin will stock them, expect the new one to fail though.
          • steve2k34
            • 36
            • uk
            Well fingers crossed it don't but if it does what ya recon the fault could be
              The IPM.
              • steve2k34
                • 36
                • uk
                Right I've put a new fuse in now the tv don't turn on, if I take it out it does!! The fuse does not blow its still good any other ideas what I could do to test
                  It means the IPM is shorted on the Z-side, so you'll need to replace it.
                  • steve2k34
                    • 36
                    • uk
                    Does that mean a whole board replace or can I get the part and is it easy to replace ?
                      It is not easy to replace but the part is only £25 or so, whole board is typically £120 unless you can find a cracked screen TV to harvest one from. I saw a 42PX5D on my local gumtree with cracked screen a few weeks ago.
                      • steve2k34
                        • 36
                        • uk
                        ill have a look around if not ill get rid of it but what part is it that needs replacing and ill look into whether id be capable of soldering it
                          The IPM.
                          https://www.youtube.com/watch?v=Y8MNQYXw8E0
                          Only necessary to swap the Z IPM.
                            LCD LED TV Service Menu Codes
                            TCL LED TV Service Menu Code
                            LG LED TV Service Menu Code
                            10-31-2024, 03:58 AM
                          • mmccomputer
                            problem with replacing lcd screen
                            by mmccomputer
                            I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                            otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                            If anyone has any information on the subject...
                            12-15-2024, 03:44 PM
                          • jimjoe123
                            LCD TV Green/Pink screen problem
                            by jimjoe123
                            I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                            Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                            Then each time...
                            02-23-2020, 01:29 AM
                          • Yehuda170
                            ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
                            by Yehuda170
                            original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
                            replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
                            now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
                            with original broken screen i can see in device manager touch screen in human interfaces
                            but with the new screen it's not showing in device manager
                            is it lenovo blocking it? is it driver missing?
                            I²C is a headache
                            07-14-2023, 01:29 AM
                          • Ryan.man
                            by Ryan.man
                            02-04-2025, 12:23 PM
