LG 37LC2DB...Inverters ??
  • Rtech
    • Jul 2010
    • 1095
    I have just purchased this, the symptoms given were Sound OK,no vision !!
    On setting up,there was no sound, no Baclight action at all,HOWEVER as I live in a different area,I accepted that,and the original Owners comment,ref the Sound.
    Measuring the Power supply outputs, I had a ON signal of 3.4v, and 24v going to both the Inverter boards.I am confident therefore that Either the Master Or Slave is faulty !!! or both !!. Caps and fuse etc look ok on both.Is there any way to detemine which is faulty ??
  • martyparish
    • Dec 2012
    • 313
    Re: LG 37LC2DB...Inverters ??
    Service manual: http://www.fixdevice.com/smanuals/file/45376.html
    Is there an INV_ON pin as well? Also, you should be able to compare the transformers secondaries resistance to see if one of them is bad.
    • Rtech
      • Jul 2010
      • 1095
      Not as far as I can see,, there is one marked I-C,and that only goes to the Master ?
      • martyparish
        • Dec 2012
        • 313
        I'm looking at the manual and see these pins labeled for the Power section:
        1: AC_DET
        2: RL_ON/Power On
        3: 5VST
        4: GND
        5: VaVs/INVERTER ON
        6: 5V_DET/ERROR OUT
        7: 3.3V ON / BRI CTRL
        8: 5VST
        9: GND
        10: NC/PWM DIMMIN
        11: 6V
        12: GND
        13: 3.3V ON
        Do you have these labels? If so, let's see what each one reads with the set powered up.
        • Rtech
          • Jul 2010
          • 1095
          Unfortunately nothing like that I'm afraid.there are two connectors for the inverters and three others for Power,and on their labelling they all test as they should.I have found a Service manual, and will Download that and see what it says. Many thanks for the help.
            Can we see the good clear pictures of the inverter boards and close up in the area of the connectors?
            • Rtech
              • Jul 2010
              • 1095
              Sorry no can do, have partially put it back together, while I sort 2 monitors and a Sharp 32" tv.
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
              • LEECH666
                Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                by LEECH666
                Good day ladies and gentleman!
                I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                01-19-2024, 05:46 PM
              • Christos Tsiligiannis
                Marian Trace Alpha sound card repair help
                by Christos Tsiligiannis
                Hello to the forum.
                My name is Christos, I am new to the forum here and i am posting from Greece.
                So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                So i tried asking for a schematic from the company and they would not give me one. Instead they...
                11-18-2024, 05:26 AM
                HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                09-12-2024, 02:30 PM
                HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
