Samsung PS50C550 (S50FH-YB06) Sound but no picture (or glow)
    Re: Samsung PS50C550 (S50FH-YB06) Sound but no picture (or glow)
    Yeah, your Va is low, very low, and it's probably causing Vs to read low, too... Can you repeat it with the two sustain boards unplugged?
      Will do,
      Also not sure if i mentioned this before but reading one of the other threads on this board you asked about relay clicks, there's relays on the psu that click when the tv is turned on and off
      not sure if they're meant to click or not
        They are meant to click.
          Ah, good.
          with both sustain boards unplugged from psu there's no voltage at either Va or Vs
          plug both boards back in and voltage goes back to where it was before
            This is normal on the C550, as they detect missing sustain boards and trigger an error. If Vs/Va are good, like around 200V and 60V, then the PSU is OK.
              So since i have 10 and .15 ish volts instead, it's more than likely the psu?
                Or the sustain boards; if they're shorted, they could cause this problem. I will have a look at this more in detail tomorrow. Will try to rule out shorted plasma panel - though very rare for Samsung. Way past bed time now.
                  Okay, thanks for your help
                    Can you post some pictures of the boards in the TV?
                      Are the drop box links earlier in the thread not working? two sec's and i'll upload them here
                        k they're kinda big and might take a while so i'll just try link my dropbox again, if it doesn't work i'll upload to the forum
                        https://www.dropbox.com/sh/4t8zukek0r36ef5/81EMZnn63s
                          Sorry, I did not notice them before, way too late last night...
                          I am working on a PS43D450 with a friend, it will not power up fully with X- or Y-main removed, but Vs/Va DO rise.
                            no probs
                            im about to sleep now but so far ive got low va and vs, dropping.
                            no va or vs with both boards unplugged
                            someone else told me drv reset means there's something gone in the hv side of the psu
                            also are the pics clear enough/links working?
                              DRV RESET is on the X- and Y-main, right?
                                I'mnot exactly sure what it means
                                The logic board (if tthat's what it's even called ) has a green led that is on for five seconds, off for two
                                According to tgohome. Info?. Com? On a similar model, that means drv reset and it doesn't say anything else, other led patterns are normal or abnormal
                                Someone else said drv reset means the logic board is detecting something wrong in the high voltage side of the psu and shutting everything off or resetting something.. I'm not too sure and to be honest I have no idea if he knew what he was talking about
                                  The LED should flash while running, if it goes out, there is a problem somewhere. I recall DS-RESET as been on the X-main and Y-main, as they feed an error signal back -- not sure if that's the same as DRV-RESET?
                                    yeah it said blink every .5 seconds is normal, every 8 is abnormal, 5 seconds on 2 off is DRV_RESET
                                    think i linked it on the first page
                                    guess i'll just keep searching around and see if someone else has come across it
                                      Do you get abnormal blinks when the Y-main and X-main are missing?
                                        Everything except power to x and y plugged in
                                        Chimes plays, logic board flashes the DRV_RESET pattern
                                          I'm out of my depth here, but I think that's normal. That is, the PS43D450 I'm working on does the same thing. Have you tried the test patterns jumper?
