Samsung PS50C550 (S50FH-YB06) Sound but no picture (or glow)
  • Aiove
    • Feb 2013
    • 24
    Done a check over on all the boards, can't find any burn marks or colour change on any boards, no caps have bulged out(haven't actually tested any yet as i'm unsure how to) checked fuses
    When it turns on there's a click from the relays on the psu, as when it's turned off, the chime plays for it turning on and then there's no picture or glow.
    the logic board has an led that lights up for 5 seconds and then off for 2, according to this page,
    http://www.tgohome.com/ServiceManual...shooting(map)_[SM].pdf
    This means DRV_RESET but doesn't explain what that actually is..
    I've tried testing voltages but either im doing something wrong or there's something broken because im getting 10 or so volts at Vs and .15volts at Va, both going down slowly. Seeing a lot of post about voltages going down is usually a stuffed cap.
    What can i do to further test the tv?
    thanks
    Re: Samsung PS50C550 (S50FH-YB06) Sound but no picture (or glow)
    Can you post a picture of the chassis and one of each board?
    Link to file - the [SM] in the URL confuses this forum - so use this instead:
    http://www.tgohome.com/ServiceManual...&Search=Submit
    • Aiove
      • Feb 2013
      • 24
      let me know if you need clearer pics and of what
      https://www.dropbox.com/sh/4t8zukek0r36ef5/81EMZnn63s
      there's still 2 or 3 uploading at the moment, will be done in a minute
      • Aiove
        • Feb 2013
        • 24
        Reading manuals on tgohome.com and one says if Va Vs are low remove both sus and see if the voltage rises
        neither did on Vs or Va, both drastically reduce to nothing either all plugged in or one or the other unplugged
        I'm starting to think it's the power supply, is there a simple way to test this?
        and if it is the smps what can i do to isolate the faulty part? im not too sure how i can check for a faulty transistor or capacitor with a multimeter
          You can load Vs with a 240V, 100W lightbulb. Are those still legal in Aus?
          • Aiove
            • Feb 2013
            • 24
            im not sure what you mean
            will a lightbulb load cause the power supply to do something different?
            does drv reset actually mean anything?
              I don't know about DRV RESET.
              The light bulb will provide a load on Vs so you can see if it remains high with just the lightbulb connected.
              Note - this chassis will shut down if it does not detect Y-main/X-main are working, so you need to force VSON high or low (and PSON high or low), I think it's low on this chassis, to turn outputs on.
              • Aiove
                • Feb 2013
                • 24
                if i start the tv up with both boards unplugged and it acts the same, the fault isn't in those boards yeah?
                also im not sure how i would "force vson"
                  There is a connector from the PSU to the control board right? Is there a pin marked VSON on either side?
                  • Aiove
                    • Feb 2013
                    • 24
                    yup, can see it
                      OK, and you see PSON?
                      • Aiove
                        • Feb 2013
                        • 24
                        yup, so jumper wire between those two pins? on which side?
                          Between PSON and GND, and also do VSON and GND.
                          • Aiove
                            • Feb 2013
                            • 24
                            so leave the connector on the psu and short the pins from the other side?
                              It should be disconnected from main board/control board and connected to PSU.
                              • Aiove
                                • Feb 2013
                                • 24
                                PSON shorted to ground,
                                No glow, no picture, plays start up chime
                                Vs constant 10volts, doesn't drop
                                Va 0.14 volts, doesn't drop
                                VSON shorted to ground
                                Va, .12 volts
                                Vs, 10 volts
                                plugged power cable back in to main board and now there's no voltage
                                • Aiove
                                  • Feb 2013
                                  • 24
                                  at Va or Vs*
                                    Sorry if I wasn't clear, you should do VSON and PSON at the same time, both are necessary. Do not expect to get a picture with main board connector unplugged -- screen -may- glow though depending on chassis design.
                                    • Aiove
                                      • Feb 2013
                                      • 24
                                      ah okay i'll try that
                                      • Aiove
                                        • Feb 2013
                                        • 24
                                        everything except Va is the same, Va was at .20volts, don't think this means much since its meant to be 55volts....
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
