Bad transformer
  • splitcrete
    • Dec 2012
    • 387
    • usa
    Bad transformer
    Hi everyone : I need some help with my proscan 32la30q
    I was checking the power board and found the f1 fuse blown.So I started looking for a reason it was bad I have a bad primary coil in one of the transformers. My problem is I cant get one any where . Its a (PULSE ELECTRONICS) number PF0082 I would be thankfull for any help.
    Thanks,Splitcrete
    Re: Bad transformer
    What resistance do you get? Primary side rarely fail, its DC resistance will typical be less than 1 Ohm. I doubt that you have bad transformer.
    Did you chekc the rectifers, MOSFET'S, etc?
    Any picutres of the boards?
    • splitcrete
      • Dec 2012
      • 387
      • usa
      Re: Bad transformer
      I have no reading at all and the transformer is off the board.
      F1 only blows with transformer on the board.
      • splitcrete
        • Dec 2012
        • 387
        • usa
        Re: Bad transformer
        The wires on the pri.side are burned off.
          Re: Bad transformer
          The transformer is just a part of the supply. Something in line with it is more than likely failed; probably a shorted MOSFET, which drives the transformer.
          • splitcrete
            • Dec 2012
            • 387
            • usa
            Re: Bad transformer
            I checked all fets and the gates work on all of them.Pain in the butt with a 9v battery.
            This set had a lightning surge and the power strip even burned out.So much for bargen power strips.
              Re: Bad transformer
              The only way to be sure is to test it with a ring tester, but I doubt you have one. Another possibility is the controller IC is damaged and the output is stuck permanently on, which will blow the fuse.
              • splitcrete
                • Dec 2012
                • 387
                • usa
                Re: Bad transformer
                No I dont have a ring tester. I was looking for a board but no luck.Mabey I can find a generic one somewhere.
                  Re: Bad transformer
                  I would first consider the controller IC. How about a picture of the board so we can locate the components on it.
                  • selldoor
                    Slow Learner
                    • 7870
                    Re: Bad transformer
                    Tom - did you see post4
                    Splitcrete - are you saying there are NO primary wires
                      Re: Bad transformer
                      Could be varnish, would need a pic.
                        Re: Bad transformer
                        Cannot do much until we see good clear pictures.
                        • splitcrete
                          • Dec 2012
                          • 387
                          • usa
                          Re: Bad transformer
Name:	2013-01-31 20.58.27.jpg
ID:	1920176I'll try to post pic.
                          • splitcrete
                            • Dec 2012
                            • 387
                            • usa
                            Re: Bad transformer
                            If more pics are needed I can post later today.
                            • splitcrete
                              • Dec 2012
                              • 387
                              • usa
                              Re: Bad transformer
                              I have more pics.And yes I'm changing all the caps most were bad.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                Re: Bad transformer
                                This may not be the case, but I saw one youtube video sometime last year where there was a thermal fuse inside the secondary windings of the transformer. Yes, I realize the OP is talking about the primary side in this thread.
                                See
                                https://www.badcaps.net/forum/showthread.php?t=18051
                                --- begin sig file ---
                                --- end sig file ---
                                  Re: Bad transformer
                                  Looks like varnish to me, nothing to worry about.
                                  What else is in series with the transformer? Other than the MOSFET...
                                    Re: Bad transformer
                                    That is PFC choke which is in series with the MOSFET to ground. You can see the MOSFET and the PFC Diode mounted on the same heatsink as the Main bridge rectifier. It will have only two windings, one is for the PFC booster, another one is for Phase detection (not all PFC uses Phase detection through the winding, so it may have only one winding)).
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      Re: Bad transformer
                                      What exactly did you mean by this?
                                      How about a clear infocus picture of the bottom of the transformer.
                                      Try in better light.
                                        Re: Bad transformer
                                        Also circle the one with open winding.
                                        Also pictures of the back side of the board.
                                          MSI Gaming Pulse GL66 12UGK-470CA Notebook GL Specification for Upgrade or Repair
                                          This specification for the MSI Gaming Pulse GL66 12UGK-470CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pulse GL66 12UGK-470CA boardview and Pulse GL66 12UGK-470CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:40 AM
                                          MSI Gaming PULSE GL76 12UEOK-692FR Notebook GL Specification for Upgrade or Repair
                                          This specification for the MSI Gaming PULSE GL76 12UEOK-692FR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PULSE GL76 12UEOK-692FR boardview and PULSE GL76 12UEOK-692FR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:38 AM
                                          MSI Gaming PULSE GL66 12UGSZOK-1096 Notebook GL Specification for Upgrade or Repair
                                          This specification for the MSI Gaming PULSE GL66 12UGSZOK-1096 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PULSE GL66 12UGSZOK-1096 boardview and PULSE GL66 12UGSZOK-1096 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          MSI Gaming Pulse GL76 12UEK-426XPT Notebook GL Specification for Upgrade or Repair
                                          This specification for the MSI Gaming Pulse GL76 12UEK-426XPT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pulse GL76 12UEK-426XPT boardview and Pulse GL76 12UEK-426XPT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:21 AM
                                          MSI Pulse 15 B13VFK-404NEU Notebook 15 Specification for Upgrade or Repair
                                          This specification for the MSI Pulse 15 B13VFK-404NEU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 B13VFK-404NEU boardview and 15 B13VFK-404NEU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-07-2024, 07:20 AM
