Panasonic TH-42PX80u Compatibility
  • crdz66
    • Nov 2012
    • 242
    Hello Fellas.
    I'm owner of a Panasonic Plasma Model TH-42PX80u
    I have a damage main board part number : TNPH0716 2 A Suffix AG
    My question is about with suffix are compatible AB, AC , ETC??????
    I find on internet one main board with no the little chip who identify wich suffix is. Do you think this is compatible with the all suffixs?
    Re: Panasonic TH-42PX80u Compatibility
    Sometimes the suffix can mean something unimportant like internal programmed model number, default start up language etc. Other times though, it can be a lot more important for example being programmed for a different plasma panel. You do not know so it is best to match the suffix.
    • crdz66
      • Nov 2012
      • 242
      Thanks for your comment
      • BigPete
        Panasonic Heatpump Dryer Repair
        by BigPete
        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
        Unfortunately the whole machine has to come apart to fix it.
        I have...
        11-01-2025, 06:40 PM
      • Andre Gilbert
        by Andre Gilbert
        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
        11-20-2024, 08:52 PM
      • AquaMan Ua
        by AquaMan Ua
        05-17-2025, 09:40 AM
      • nix30101
        Thoughts on Reverse Engineering 8FC8 suffix logic..
        by nix30101
        Greetings i am in the process of reverse engineering the bios logic for the 8FC8 suffix so far I have found most of the bios functions related to the suffix from a bios dump and I have verified inputs and outputs to test with plus the chartable for the 8FC8 suffix.
        12-16-2024, 12:50 PM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
