Sanyo DP46849 46" LCD - Does not power up.
    Re: Sanyo DP46849 46" LCD - Does not power up.
    EN/UV to SOURCE is suspicious. EN/UV is supposed to either connector to DRAIN (for undervoltage lock out) or across an optocoupler... 330 ohms is very smaller.
      Hmm, what happen to my reply on the EN/UV pin, yes, it is way too low. Can you remove the IC and measure the resistance again without the IC in place?
      • Deebeaux
        • 31
        Tomorrow I will remove IC and re-test EN/UV to 4 Source pins.
        I also received a reply in e-mail from the forum that didn't show up in the post...
        Originally posted by retiredcaps
        Originally posted by Deebeaux
        I ordered some 47 Ohm 1W resistors since I couldn't find any in my stash,
        You can use a CR2032 3V battery or two AA batteries in series instead. Most PS_ON pins wii go high with 3V. The postive terminal of the battery goes to the PS_ON pin and negative goes to ground.
        Should this be attempted before removing the IC or was it removed from the post purposely?
        Best Regards,
        Dave (aka Deebeaux)
        • retiredcaps
          • Apr 2010
          • 9271
          Pay no attention to my post above. I had multiple windows open and cut & paste into the wrong window.
          That is the problem with having 2 lcd screens and multiple windows open.
          --- begin sig file ---
          --- end sig file ---
          • retiredcaps
            • Apr 2010
            • 9271
            Nothing looks obviously shorted with the IC.
            And this why it helps to have multiple inputs on the problem. Obviously, my brain was somewhere else with my incorrect post (3V battery).
            • Deebeaux
              • 31
              Thanks for the info. I only mentioned it incase there was some forum glitch and it got lost unintentionally. I'll get that IC out today and retest. My 47 Ohm 1W resistors won't be here until Thur/Fri most likely.
              Best Regards,
              Dave (aka Deebeaux)
              • Deebeaux
                • 31
                Just got the IC off the board, despite my desoldering pump committing suicide midway through the procedure (The plunger flew out of the end and landed somewhere in the shop. I didn't even look for it, I ordered a new one.), and pin 1 EN/UV to any of the four S (Source) pins (5,6,7,8) still read ~330 Ohm. (329.95-300.01). I doubled checked to make sure I'm getting Pin 1 right, and confirmed it as it has the tell-tale dot on the IC itself, as well as the pin configuration (3 on one side, 4 on the other).
                Does this lean toward a bad IC? I wouldn't be surprised if it's not the only bad part in this unit, but progress could be fun.
                OK, check this diode..
                I had the iron out so I lifted one leg and checked that diode from earlier. Here are the results:
                Black on Anode, Red on Cathode = 0 VDC
                Red on Anode, Black on Cathode = 0.2215 VDC
                I also got the full part number, it's in 2 lines:
                LT746
                SB560
                Still waiting on resistor for load to test voltages on the IC that I removed.
                Best Regards,
                Dave (aka Deebeaux)
                  So you you are still readin 300 Ohms on the IC pin?f that is the case, more likely that IC is bad. I would get another one.
                    0VDC, or "OL"?
                    The TNY IC is failed. Perhaps a power surge killed it. It is strange that power surges seem to happen a lot in US, but I've never seen a single device in the UK damaged by such!
                    • Deebeaux
                      • 31
                      Yes, still 300 Ohm between Pin 1 and any of the source pins (5, 6, 7, 8). I'll order another one for starters.
                      0VDC, or "OL"?
                      Definitely 0 VDC and not OL. With you being the 2nd recommendation of replacing that IC I'll try to locate and order one tomorrow. I'm guessing this was the result of a power surge. There are 3 TVs that I'm working on from the same location as a result of a surge. One was simply a blown fuse and is back in service, the second needed 2 capacitors replaced to bring it back to life but I've also discovered that all the HDMI ports have failed while other ports work (I'm thinking main board at this point), and the third is this TV you've all been helping me with that appears to have a sick power supply.
                      Best Regards,
                      Dave (aka Deebeaux)
                        I have never seen a diode fail with a 0V and 0.22V measurement. You have discovered a new form of zero-drop semiconductor that engineers have been trying to make for years... shame it has only a 0.22V reverse rating . Please test it again for my personal sanity. Consider ordering a replacement for your personal assurance... and mine.
                          If it is that shorted, you should be able to see O ohm on the Ohm meter.
                          • Deebeaux
                            • 31
                            Oh, wow, I didn't even catch that. My personal sanity is now in question and I can hear my high school electronics teacher scolding at me for not paying attention. I was rushing to get out of the office, at the time I was sure it didn't read OL, but now I'm questioning it. When in diode test on the Fluke 189 I know it'll show OL, but I tried it twice and it just read 0 VDC? (I think.) I'll check it again using diode check and resistance when I get to the office tomorrow. Would make sense to order another since it'll likely be inexpensive and I'm going to get taken to the cleaners on shipping anyway with only shipping one IC anyway.
                            Best Regards,
                            Dave (aka Deebeaux)
                              If you do find this device has a zero-volt drop, send it to the semiconductor lab at my university as they'd probably be interested:
                              Institute of Microwaves and Photonics
                              Electronic and Electrical Engineering
                              University of Leeds
                              West Yorkshire
                              UK
                              But I'm betting it's OL and 0.22V
                                I would like to send that to my friends at Fairchild semiconductor also (I worked there for 10 years).
                                  Tell you what, we can split it in two and send it to both labs.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #37
                                    I'll buy the defective Fluke 189. PM me.
                                      Would you also like to buy 60 defective Agilent U1241B's?
                                      My university lab is full of them and every... single... one has a defect where when left alone for several minutes, it will go crazy and start reading massively positive or negative voltages, 0V on diode test no matter what's connected and 100 or so ohms with the probes open.
                                      Lab tech says they're due to be upgraded in a year or so, and if they end up throwing these out, I'm sure as hell grabbing some. Apparently, they just need a firmware update...!
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #39
                                        Some? Grab them ALL.
                                        I'm very surprised at the lack of action with these malfunctioning multimeters.
                                        People are supposed to trust the readings before taking potential action. For example, if the Agilent reads 0V across the legs of a large filter capacitor which in reality is charged to 400V, there could be serious problems if I start to desolder it.
                                        As you are aware, Dave Jones, has found a lot of problems with the Agilent handhelds and if they were never firmware upgraded, it could be an easy fix (don't forget to send me one). A lot easier than picking up massively heavy monitors and repairing them.
                                        PS. To show I'm not a Fluke fanboy, Fluke have their own problems as evidenced in this latest recall of products.
                                        http://www.fluke.com/fluke/usen/support/safety/
                                        http://www.fluke.com/fluke/usen/supp...37X-Recall.htm
                                        January, 2013
                                        Description of the problem
                                        The printed circuit assembly may not be properly fastened to the test lead input jack. This may result in inaccurate voltage readings, including a low or no voltage reading on a circuit energized with a hazardous voltage, presenting a shock, electrocution or thermal burn hazard.
                                        • Deebeaux
                                          • 31
                                          University of Leeds
                                          West Yorkshire
                                          UK
                                          Bad news guys, I haven't made any sort of revolutionary discovery. Definitely 0.22V and OL. I saw a O and the VDC in the corner lit, so I went with it. Was trying to get out of the office at the end of the day, seems to effect accuracy around here. I'll just change my nickname to "zero-volt drop" since I doubt I'll ever live that down.
                                          Will order the IC today and replace and then go from there.
                                          Sorry, Fluke 189 doesn't appear to be defective, the operator however...
                                          Best Regards,
                                          Dave (aka Deebeaux)
                                          • Ady2017
                                            SMD fuse soldering advice please
                                            by Ady2017
                                            Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
                                            11-07-2025, 12:03 PM
                                          • cj_reha
                                            Mystery 80s Sanyo cap - perhaps polymer?
                                            by cj_reha
                                            Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                                            01-06-2023, 09:24 AM
                                          • chazzo
                                            CH341 programmer advice, including jumpers seemingly reversed
                                            by chazzo
                                            I’d appreciate some very basic advice on CH341x programmers. I know this topic comes up from time to time, but stuff changes, so I hope a refresh is in order. In particular, I see some unexpected things happening with jumper positions.
                                            [My plan is to learn to read and write 24CO2 EEPROMs via I2C. The first target is the one in my Uni-T clamp meter, but before tackling that I have some brand-new EEPROMs to practice on.]
                                            I have two basic Chinese programmers. One is the blue board with a CH341A and two rows of pin headers. To my untrained eye it looks like all the others....
                                            10-12-2025, 08:15 AM
                                          • Jidis
                                            Need T-Con Advice (Vizio P602ui-B3)
                                            by Jidis
                                            I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                                            He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                                            09-22-2025, 05:10 PM
                                          • zlr8r
                                            Advice on newer EC chip programming eg. MEC5107-LJ BGA
                                            by zlr8r
                                            Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
                                            i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
                                            09-16-2025, 09:54 AM
