Insignia NS-LCD15-09 -- Won't Turn On
  • PohTayToez
    • Jun 2010
    • 80
    The Pictures
    Power Board
    Main Board
    Unless I'm missing something, it seems to be the back light is powered directly by the power board with no separate inverter board.
    When plugged in the status light goes red. When you hit the power button the light turns blue for a split second then goes out and starts blinking red. It blinks five times and then on the sixth blink it stays red and you can try and turn it on again with the same results.
    There are no visibly failed capacitors.
    Here are the readings I got off of the power board output to the main board:
    +12V = 12.59v
    GND = .00v
    +5V = 5.12v
    ON/OFF = .00v
    DIM = -.03v
    Not sure what to do next... should I start testing voltage regulators? Also I was not able to identify any sort of fuses to be tested.
    Re: Insignia NS-LCD15-09 -- Won't Turn On
    ON/OFF and DIM are low.
    Suspect the main board.
    There are many regulators on it. Please test them. https://www.badcaps.net/forum/showthread.php?p=300999#
    • PohTayToez
      • Jun 2010
      • 80
      Should I be able to get a reading off of the regulators since it won't come out of standby? I was only able to get a measurement off of one:
      U706
      885
      17-33L
      Pin 1 = 0.00v
      Pin 2 = 3.28v
      Pin 3 = 5.12v
      Also, random question but a lot of the regulators are labeled with what looks like a backwards "C" followed by "11". Can you tell me what that means?
        OK, can we have a picture of the main board?
        Can you acquire some 1k ohm resistors? We can make the backlight and dim voltages high, so the screen can be tested.
        • PohTayToez
          • Jun 2010
          • 80
          Main Board
          I'll have to see what I can do on the 1K ohm resistors, I may have to order some. Is there any other testing I can do in the meanwhile?
            What resistor values do you have?
              So what do the other regulators measure on the board? Zero, nearly zero (<0.1V)?
              • PohTayToez
                • Jun 2010
                • 80
                I do not have any resistors at all, I might see if I could salvage some but I will probably just order them. How many do I need?
                They all measured at less than .01v (i.e. I had the multimeter set to measure out to two decimal places and everything read at .00v)
                  You may need at least 2, one for the Power supply ON (PS_ON), and one may be for the Backlights ON (BL_ON/INV_ON/OFF) just in case, but from the l0oks of it, the power supply is an always on power supply, so you just need 1 for the ON/OFF (BACKLIGTS ON/OFF control).
                    By the way, I can see at least 3-pin devices that look like Voltage regulator ICs that you need to check. So far I agrre with Tom that you do have bad main board problem and not sure if it will be worth fixning or not for this small TV, it will not be too bad if it onlt has bad regulators, anything other than that will require more in depth troubleshooting and times which I do not know how mush time you are willing to spend on component level troubshooting, beside, do you have the tools to do surface mounted repair?
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Originally posted by PohTayToez
                      Main Board
                      A couple of things.
                      1) We prefer pictures attached following the instructions in my sig file exactly for a number of reasons.
                      2) Using the above method, tom66 would have seen the main board as a thumbnail in post #1.
                      3) To turn on PS_ON or BL_ON, you can use a CR2032 3V battery or 2 AA batteries in series.
                      --- begin sig file ---
                      --- end sig file ---
                      • PohTayToez
                        • Jun 2010
                        • 80
                        Originally posted by retiredcaps
                        A couple of things.
                        Sorry about the picture, I figured I'd take it at the highest resolution for max detail. As for #3, will that allow me to test the voltage regulators? Someone else said they thought it might be an "always on" PSU. How would I need to hook up the battery?
                        Right now I have only been able to test in standby and in standby only one of the regulators is getting power. As for replacing surface mount components that will actually be the easy part for me.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          No, it will only do the test tom66 mentioned in post #4, namely test the screen comes on.
                          As soon as you plug in consumer electronic device made today into the wall socket, the standby power supply is autmoatically on.
                          The positive terminal of the battery goes to the BL_ON pin and the negative terminal of the battery goes to cold side ground.
                          • PohTayToez
                            • Jun 2010
                            • 80
                            Sorry for my ignorance and all the questions. I really am trying to learn and figure out what I can on my own but I'm still not sure what to do.
                            Am I looking for something actually labeled "BL_ON", because I do not see it. Two of the pins on the PSU output are "DIM" and "ON/OFF"; could it be either one of those?
                              Yes, this TV uses ON/OFF instead of BL_ON. You can ignore DIM for now or connect it to ON/OFF, but either way the screen glow should be visible.
                              • PohTayToez
                                • Jun 2010
                                • 80
                                The backlight does indeed come on.
                                BTW thank you (everyone) for your help so far.
                                • PohTayToez
                                  • Jun 2010
                                  • 80
                                  Hey so am I supposed to be able to get a reading on all the voltage regulators when it's in standby? Could one of them having failed be the reason I'm not getting a reading on the others?
                                  Also can I be reasonably certain that the power supply is not the cause of the problem? Replacement main boards for this unit are not terribly expensive, but if I'd like to fix it if I can.
                                  • PohTayToez
                                    • Jun 2010
                                    • 80
                                    So if there are no more suggestions I guess I'll be ordering a replacement board...
                                    • PohTayToez
                                      • Jun 2010
                                      • 80
                                      Replacement main board did the trick
                                      • brzostos
                                        HP ENVY X360 15-EU0005NA 203037-2 does not turn on, something whistles on the board.
                                        by brzostos
                                        Hello, HP laptop model 15-EU0005NA. It does not turn on, 1 in 100 manages to turn it on then after a while it freezes/disappears/flashes, etc.
                                        After removing the motherboard and connecting the board with RAM to the power supply, I noticed that at first all voltages start correctly and after a few seconds 3.3V on the PL4501 coil disappears and somewhere in this area something starts beeping on the board, sometimes after touching it with a finger in the area of PL4551 it stops beeping and 3.3V appears again.
                                        Original HP 150W power supply, the diode in the power socket lights...
                                        10-01-2024, 01:34 AM
                                      • Tynan Dill
                                        by Tynan Dill
                                        Assuming...
                                        11-22-2024, 01:46 PM
                                      • m1ch43lzm
                                        by m1ch43lzm
                                        05-12-2025, 08:37 PM
                                      • Hakuu
                                        by Hakuu
                                        Hi There,
                                        More Details
                                        TV Model - LG OLED77G1PUA
                                        07-12-2023, 02:37 PM
                                      • jb_Bak
                                        by jb_Bak
                                        CN6401
                                        Pin 01 NC
                                        Pin 02 NC
                                        Pin 03 "BL_ON": 0V
                                        Pin 04 "N/C"
                                        Pin 05 "STBY 3.3V": 3.5V
                                        Pin 06 "GND": N/C
                                        Pin 07 "AC_OFF"...
                                        09-27-2021, 04:52 PM
