Re: panasonic tc-p60st30 won't turn on
OK, I now suspect that your panel is perfectly fine, but you have an A Board issue still, you say you replaced it but it is giving very odd digital artefacts. The vertical bar of noise has me concerned though, does it move and change or is it static?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
In which case it is the A Board. Have you replaced this with a known good board?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Reseat all the cables and see if the symptoms change. Is the A Board a guaranteed match for this model?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I suggest you reseat all of the main ribbon cables. Make sure you make all wiring changes with power unplugged.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Look like the lcd is cracked in the corner. It happen went i was moving it. right went it start working. well what can i do, this things happens. Soon or later i am going to make it. I will not give up, i am going to learn. Once again tom66 i am very grateful. Tomorrow i have a vizio that i can see but has no volume, let see what happen. Thanks you.Comment
It is a plasma display not an LCD. You will not get any image if the display is cracked.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by canadaboy25I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was... -
by tikuHello Friends, i am having this model Panasonic TH-L32C30D, suddenly when i switch on, it went on One Blink, after looking at the service manual it says Backlight_SOS, I can see the menu on the tv screen for few seconds in the dark with the help of flashlight Before it goes into blinking cycle.
I was having a backup P-Board which i replaced it and now its working fine, but i need to repair my faulty P-Board, as now its getting dificult to find any type of spares of this model, so can any friend who is master in Panasonic Repair, be kind enough to guide me or tell me which component should...09-05-2021, 05:02 AM -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by dajokerMy old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
I chased my way through the PSU, and a board, with no results.
Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
I only have the right half of the picture.
Left half is completely blank.
now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
all the other voltage rails...09-24-2024, 04:39 AM - Loading...
