Vizio VW42L FHDTV10A (Newbie Post)
  • PohTayToez
    • Jun 2010
    • 80
    Long time lurker, first time poster here. I've been fixing electronics for years, mainly computers, cell phones, and iPods. I've dabbled in some monitor/TV repair, but while I have no trouble replacing any sort of component I never properly learned how to diagnose them (outside of spotting visible bad caps)
    Anyway, I have a Vizio TV I'm working on. The status light goes from amber to white when you hit the power, but otherwise does nothing (no backlight, vid or sound). I've read about a dozen or so threads from here on this model and it seems like it's a common problem with many possible causes.
    So first things first, here are the pictures:
    Power Board
    Main Board
    T-Con Board
    Inverter Board
    Inverter Board (Close Up)
    What I've tested so far:
    Power Board:
    Outputs going to inverter:
    24V = 25.26v
    A = 5.05v
    B = 3.33v
    Outputs going to main board:
    PSON = 3.19v
    12V = 11.83v
    5V = 5.16v
    A = 3.35v
    B = 5.07v
    T-Con Board:
    Fuse tested good
    Inverter Board:
    Fuse tested good
    Main Board:
    Both fuses tested good
    Tested all the voltage regulators I could find:
    U20 = 2.76v/1.25v (VI/VO)
    U19 = 2.81v/1.25v
    U15 = 2.98v/1.25v
    U22 = 3.02v/1.26v
    U44 = 2.63v/1.25v
    U17 = 2.97v/1.26v
    U21 = 2.51v/1.26v
    U16 = 10.84v/5.07v
    Oh and there are no visibly failed capacitors.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Vizio VW42L FHDTV10A (Newbie Post)
    We have no idea if the regulators are good or not without knowing
    1) the part number of the regulator
    2) the reading on all 3 pins
    My sig file below shows the preferred easy to read format for reporting the above.
    --- begin sig file ---
    --- end sig file ---
    • DakotaKid
      • Nov 2010
      • 165
      In addition, are you sure you don't have a VW42LF with "F" at the end rather then VW42L in your title? I've worked on some VW42L and they have a similar but very different main board than your picture. VW42L is 720p, VW42LF is 1080p so it is pretty easy to figure out which you have in addition to the model on the back label. The VW42L schematic (which I have) is no use for your troubleshooting. I don't have schematic for VW42LF.
      I've worked on a few VW42L's and with the symptoms you describe I always, in my cases, found it to be a faulty LDO regulator, usually U33 if I remember right. Once the output of one regulator is off spec then all bets are off on how the board will act because other inputs rely on outputs of these LDO's and Vizio has a history of board design and/or component failures with these LDO's in the VW and VX series.
      Complete speculation but I do believe you'll find that one of those LDO's is out of voltage spec either from it failing so something supplying voltage to it. But, as retiredcaps said, none of us can really help without more details on the parts and more thorough readings of all 3 pins.
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        The one inverter board that you posted a picture of has 3 bad caps. They are bloated. Please post the picture of the other inverter board, if there is one on the other side.
        You will also need to check the FETs and the fuse on the inverter board(s).
        • PohTayToez
          • Jun 2010
          • 80
          Hey, I just wanted to say thanks and sorry for not giving good information the first time around. I can't believe I didn't notice the capacitors bulging on the inverter too. I'll order some replacements right away. I also went ahead and redid all of my readings properly:
          Power Board:
          24V = 25.26v
          SGND = .02v
          A = 3.35v
          B = 5.07v
          PSON = 3.19v
          12V = 11.84v
          SGND = .00v
          5V = 5.17v
          A = 3.35v
          B = 5.07v
          T-Con Board:
          Fuse tested good
          Inverter Board:
          Fuse tested good
          Main Board:
          Voltage Regulators:
          U20
          C11
          1084
          0745DL
          Pin 1 = .55v
          Pin 2 = 1.81v
          Pin 3 = 3.32v
          U19
          C11
          1084
          0745DL
          Pin 1 = 1.26v
          Pin 2 = 2.52v
          Pin 3 = 5.07v
          U15
          C11
          1084
          0745DL
          Pin 1 = 2.09v
          Pin 2 = 3.35v
          Pin 3 = 5.07v
          U22
          AMC1117
          F0748F
          Pin 1 = 2.10v
          Pin 2 = 3.36v
          Pin 3 = 5.12v
          U21
          AMC1117
          F0748F
          Pin 1 = .00v
          Pin 2 = 1.26v
          Pin 3 = 2.51v
          U17
          AMC1117
          F0748F
          Pin 1 = 2.10v
          Pin 2 = 3.37v
          Pin 3 = 5.07v
          U44
          K022
          G9117
          Pin 1 = 8.42v
          Pin 2 = 9.68v
          Pin 3 =10.83v
          U16
          7805CT
          RNT707G
          Pin 1 = 10.82v
          Pin 2 = .00v
          Pin 3 = 5.06v
          There is only one inverter board. (Picture of all the boards for reference)
          I did check the fuse on the one board. Is there a guide here on identifying and testing FETs?
          (Picture of back label)
          It is definitely not a VW42LF, which I read about in other threads here. U33 on my main board is an 8 pin chip.
            U20
            C11
            1084
            0745DL
            Pin 1 = 1.55v
            Pin 2 = 1.81v
            Pin 3 = 3.32v
            This regulator is suspect. Please re-test it. If you get the same results it may be failed.
            • PohTayToez
              • Jun 2010
              • 80
              Sorry, my mistake. The correct reading on pin one is .55v not 1.55v
                In which case the regulator is functioning correctly.
                A = 3.35v
                B = 5.07v
                When the logo is orange (TV is in standby) what do these read?
                When the TV logo is white does pressing the power button make it go orange?
                I suspect your inverter is faulty. Everything is working but the backlight is not showing so you'll see no image.
                • PohTayToez
                  • Jun 2010
                  • 80
                  A = 3.35v
                  B = 5.07v
                  In standby A reads .20v and B reads .02v.
                  Yes.
                  I am suspecting this as well. I will try powering it and shining a light on the screen to see if I get an image.
                    This definitely leans towards inverter fault.
                    Note some LCD panels don't let you see an image with a flashlight, it's due to their design.
                    • PohTayToez
                      • Jun 2010
                      • 80
                      Yeah, I'm not able to see anything but I'll go ahead with replacing the caps on the inverter and go from there.
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        I had the 47" version of this set come across my bench. I couldn't get the amber Vizio logo to go white. The issue turned out to be bad caps on the inverter and PSU and a bad fuse on the inverter as well. I replaced these components and the set fired right up. I kinda skimmed through your posts so I apologize if I missed this. Did you check fuse F1 next to pin 1 of CN1 on the inverter?
                        • PohTayToez
                          • Jun 2010
                          • 80
                          Yes, I found and checked one fuse on every board and two on the input board.
                          • PohTayToez
                            • Jun 2010
                            • 80
                            Just wanted to follow up on this in case someone else has the same problem -- it was the capacitors on the inverter and nothing else. Thanks for the help! I feel silly for not being able to determine the problem myself.
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              It happens. Good job saving it.
                              • logonsys
                                • Jul 2012
                                • 25
                                I know this is an older post but can I ask a quick question and hope for a response? First off, I was out here about 3 years ago with my Vizio VW426 no pic, no sound, and you guys were able to help me. It was a bad main board. Although I can replace a board, I don't have the eyesight or steady hand to do board level repairs. Anyway, the pic and sound are going out again intermittently. Seems after it has warmed up. The remote still works, can power on and off with it. I have already replaced the main board again but this time didn't fix it. So, my question is, power supply, inverter, or T-Con? Keeping in mind I get no picture and no sound, light stays white. I can power off, wait a few minutes, power back on and it will work for anywhere from 5 minutes to an hour. What would be the best guess at what board to replace next? Any help would be greatly appreciated. Thank you!
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  The fact that both sound and pic are cutting out makes me think power supply. If it was just pic, the T-con would be suspect. If it was just sound, main or power supply. Are there any bloated caps on the PSU?
                                  • logonsys
                                    • Jul 2012
                                    • 25
                                    Thanks for the fast response! No bloated caps that I could see. I also noticed I have greying/darkening around the edges of the TV when it's working. Could it be that the backlight bulbs are going?
                                    I'll try to get some pics but the camera on my phone does not have great resolution.
                                    • Dgtech
                                      E. Technician
                                      • Apr 2009
                                      • 1462
                                      • Steeler
                                      I worked on more vizio vw42l tvs than any other set . In most sets the inverters, one or the other was the problem. Usually if just the sound goes...i would suspect the slave inverter. If both...then the master is bad. Do you have a way to check voltages and resistances? If so... with powrr off...check the resistaces across each of the four fets on each inverter and post your findings.
                                      • logonsys
                                        • Jul 2012
                                        • 25
                                        This tv has only one inverter board to the left of the main (when looking from the open back of the set). I have a volt meter so I'll check those tonight while I'm waiting for my tile to set/dry. Right in the middle of a kitchen remodel. Nothing like juggling several unrelated projects!
