Philips 42PF7421D 2006 - multiple clicks, red LED, one long one short blink
  • MoTVmoProblems
    • 5
    • usa
    I took off the back hoping to find some bad caps but I don't see any that look suspect on either the main board or the power supply board. Is it possible for them to be bad without any visible signs? I replaced 4 on the power supply board, that i was able to find at the local radio shack, but there are many that remain untouched. The same problem happens with the clicks and the same light code after i reattach everything.
    I have already ordered a new main board and a new power supply board just in case...but they were costly so i'd rather just solder what i need to and return the boards. Also I don't think i can return either board once I open and install them, so if I install the wrong one first, i'm stuck with both boards when i only need one.
    If anyone has any ideas, let me know!
    Edit: 2006 is the year, not part of the model number
  • MoTVmoProblems
    • 5
    • usa
    Re: Philips 42PF7421D 2006 - multiple clicks, red LED, one long one short blink
    Bump =\
      You can't use RadioShack capacitors in a PSU, they are the wrong type (not low ESR.)
      • MoTVmoProblems
        • 5
        • usa
        OK thanks
          You can buy low-ESR capacitors from
          http://www.digikey.com/
          or the owner: https://www.badcaps.net/
          Panasonic FR, FM and FC are good suggestions.
          • MoTVmoProblems
            • 5
            • usa
            Does it not matter which of those 3 i use?
            Side question...I just ordered a multimeter. Does that check diodes as well? I hear those tend to go bad with the caps on the Philips tvs
              A multimeter can sometimes be used to test diodes if it has a diode test range, a great deal of multimeters do.
              "FR" is the best capacitor, though FM and FC are both excellent. I would rank them from "excellent" to "very good".
              • MoTVmoProblems
                • 5
                • usa
                Great info, thanks. I'll post back with results.
                • djordje
                  Philips 55 oled 804/12 red light blink
                  by djordje
                  Hello all,
                  I have Philips Oled 55 (804/12) with black screen and red light blink.
                  I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                  Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                  When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                  My questions is what should i do next...
                  01-03-2025, 04:00 PM
                • cloo
                  Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                  by cloo
                  I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                  It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                  So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                  After doing a factory reset this problem was gone and the picture was back to...
                  01-06-2025, 06:02 AM
                • EazyBone
                  Un50cu7000 2 blink oddity *partially solved
                  by EazyBone
                  I write this to maybe help another with this TV.
                  So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                  The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                  03-18-2024, 10:24 PM
                • Sharpa
                  Repair attempt Philips 55OLED804/12
                  by Sharpa
                  I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                  The symptoms when bought: Philips logo appears then tv turns off
                  Things tried so far:
                  1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                  2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                  11-22-2025, 08:30 AM
                • Dvsr
                  Philips 55PFL8008S/12 two blink error code
                  by Dvsr
                  Hi. This noob needs help with this TV.
                  Symptoms: TV haven't always turned on but when it has, it has been working normally. The TV was sitting in the storage for about an year and after that time for a few days it worked perfectly and turned on every time. But then it suddenly won't turn on anymore and just shows two blinks with standby light.
                  I disassembled the back cover and examined the circuit boards. I didn't notice anything obvious with PCBs and components. I measured the voltage rails. In the connector that connects to logic board every voltage is present and...
                  02-05-2023, 10:36 AM
