Philips 42PF7421D 2006 - multiple clicks, red LED, one long one short blink
  • MoTVmoProblems
    • 5
    • usa
    I took off the back hoping to find some bad caps but I don't see any that look suspect on either the main board or the power supply board. Is it possible for them to be bad without any visible signs? I replaced 4 on the power supply board, that i was able to find at the local radio shack, but there are many that remain untouched. The same problem happens with the clicks and the same light code after i reattach everything.
    I have already ordered a new main board and a new power supply board just in case...but they were costly so i'd rather just solder what i need to and return the boards. Also I don't think i can return either board once I open and install them, so if I install the wrong one first, i'm stuck with both boards when i only need one.
    If anyone has any ideas, let me know!
    Edit: 2006 is the year, not part of the model number
  • MoTVmoProblems
    • 5
    • usa
    Re: Philips 42PF7421D 2006 - multiple clicks, red LED, one long one short blink
    Bump =\
      You can't use RadioShack capacitors in a PSU, they are the wrong type (not low ESR.)
      • MoTVmoProblems
        • 5
        • usa
        OK thanks
          You can buy low-ESR capacitors from
          http://www.digikey.com/
          or the owner: https://www.badcaps.net/
          Panasonic FR, FM and FC are good suggestions.
          • MoTVmoProblems
            • 5
            • usa
            Does it not matter which of those 3 i use?
            Side question...I just ordered a multimeter. Does that check diodes as well? I hear those tend to go bad with the caps on the Philips tvs
              A multimeter can sometimes be used to test diodes if it has a diode test range, a great deal of multimeters do.
              "FR" is the best capacitor, though FM and FC are both excellent. I would rank them from "excellent" to "very good".
              • MoTVmoProblems
                • 5
                • usa
                Great info, thanks. I'll post back with results.
                • djordje
                  Philips 55 oled 804/12 red light blink
                  by djordje
                  Hello all,
                  I have Philips Oled 55 (804/12) with black screen and red light blink.
                  I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                  Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                  When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                  My questions is what should i do next...
                  01-03-2025, 04:00 PM
                • cloo
                  Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                  by cloo
                  I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                  It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                  So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                  After doing a factory reset this problem was gone and the picture was back to...
                  01-06-2025, 06:02 AM
                • EazyBone
                  Un50cu7000 2 blink oddity *partially solved
                  by EazyBone
                  I write this to maybe help another with this TV.
                  So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                  The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                  03-18-2024, 10:24 PM
                • Dvsr
                  Philips 55PFL8008S/12 two blink error code
                  by Dvsr
                  Hi. This noob needs help with this TV.
                  Symptoms: TV haven't always turned on but when it has, it has been working normally. The TV was sitting in the storage for about an year and after that time for a few days it worked perfectly and turned on every time. But then it suddenly won't turn on anymore and just shows two blinks with standby light.
                  I disassembled the back cover and examined the circuit boards. I didn't notice anything obvious with PCBs and components. I measured the voltage rails. In the connector that connects to logic board every voltage is present and...
                  02-05-2023, 10:36 AM
                • alro7779
                  Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                  by alro7779
                  Hello, guys!
                  The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                  09-14-2025, 12:25 AM
