possible purchase Hitachi L47x02a
  • TimT
    • Nov 2012
    • 268
    • us
    Hi everyone, I was wondering if anyone is is familiar with Hitachi l47x02a? it's a 1080 plasma. $30 with a 32 inch emerson both for $30. I think parts would be hard to find for the Hitachi both have good screens. should I buy these?
    Re: possible purchase Hitachi L47x02a
    L47X02A is an LCD.
    $15 each is pretty good, the Emerson would be easy to fix, then you could focus on the Hitachi.
    • TimT
      • Nov 2012
      • 268
      • us
      I think I will buy them..and just now talked to someone with a 55 toshiba he said it was LCD and Half the screen would go out... sounds like a Plasma to me
        You only get 55" plasmas from Hitachi and Panasonic (2010 onwards), and as far as I know, Toshiba only ever used LG or Samsung plasma panels in their plasma TVs. Most likely it's a 52" LCD by Samsung (display panel) with tab bond defect, or a 55" LCD by LG Display (who have a small problem with some older display panels.)
        • TimT
          • Nov 2012
          • 268
          • us
          your right it's a Toshiba REGZA 52RV535U LCD half the screen goes out. he wants $50
            It's bad tab bonds. Fix:
            https://www.youtube.com/watch?v=xHst6pKLtTE
            46" and 52" panels have half picture faults. Varies depending on the exact failure. 40" ones have full picture faults.
            Go for $35, max, imo. Because you can so easily **** up the panel trying to fix tab bond issues, if you are careless.
            • TimT
              • Nov 2012
              • 268
              • us
              Tom I am not sure if this Tv has the same issue..This is the picture 99% of the Time. once before I had programed the chanels it had a " full menu" picture. it's rare but sometime the right side has a different pattern.
                Yep, that is tab bonds.
                https://www.badcaps.net/forum/showth...371&highlight=
                • TimT
                  • Nov 2012
                  • 268
                  • us
                  thanks for the information! that's good news for me. and thanks for the link that will be useful. I'll be working on this TV tonight.
                  • TimT
                    • Nov 2012
                    • 268
                    • us
                    Don't think it's a Tab Bond issue. could not find any issues with the tabs. so I was thinking bad panel then I noticed there was a spot that if I touched would clear up the picture. it looks like a testing pad?. used a small screw driver to make contact with the " pad " pad is marked in picture. panel is fine for now can't seem to get the panel to mess up anymore. but worried it's not fixed don't know why touching the pad with screw driver fixed the picture?
                      The panel bondings are very sensitive and just flexing the board slightly can often temporarily fix the tab bonds. And sometimes it's not possible to see the problem, as it's not always visible.
                      • TimT
                        • Nov 2012
                        • 268
                        • us
                        was touching them to no avail..only when I put my finger on the " pad " did the screen start to clear up.. the last time the screen was bad all I did was gently touch the pad with screw driver.. was about to give up because touching the tab bonds did not help
                        • Jaime Morillo
                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                          by Jaime Morillo
                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                          The TV was stuck on the logo and I couldn't access the update menu.
                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                          The image result was good, but the image is inverted.
                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                          08-18-2025, 11:38 AM
                        • wolf1976
                          hitachi 50hk5600 problem with display
                          by wolf1976
                          hi
                          i have the above tv and the display starts distorts the display at only in applications like you tube
                          after and on the didital channels
                          now without connect the antenna only the image of itsselfs tv i have the image i have in attach
                          i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
                          can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
                          09-13-2025, 02:26 PM
                        • prodigy83
                          MacBook Pro M1 Pro Logic Board 820-02100 Mosfet where to purchase?
                          by prodigy83
                          My reference only: TT10141.
                          Problem: I need to purchase a mosfet chip from board 820-02100 M1 Pro, that is supposed to be Q5820 but according to Digikey, the schematic diagram I sent them, neither are relevant to the actual mosfet specification I sent them. I just basically need to find this mosfet to purchase, I cannot find it anywhere and am hoping someone could point me in the right direction without have to purchase this entire allusive board. Already checked with Digikey, Mouser, Aliexpress, eBay. Any suggestions?
                          Mosfet specs are as follows:
                          Chip markings:...
                          03-12-2024, 01:38 PM
                        • massimomax
                          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                          by massimomax
                          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                          spero che qualcuno può averlo per riprogrammare eprom. grazie
                          Post in English !!!
                          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                          02-28-2025, 07:27 AM
                        • dragometin
                          Hitachi 40HYC42
                          by dragometin
                          TV Model: Hitachi 40HYC42
                          Power Supply: 17IPS71
                          MainBoard: 17MB95M
                          Panel: VES400UNDS-2D-NO3
                          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                          Is there any variants on 17IPS71 power supply's?
                          UART output pins 10 and 12 on scart connector:
                          Code:
                          12:24:04.595
                          08-08-2024, 05:53 AM
