Hi everyone, I was wondering if anyone is is familiar with Hitachi l47x02a? it's a 1080 plasma. $30 with a 32 inch emerson both for $30. I think parts would be hard to find for the Hitachi both have good screens. should I buy these?
possible purchase Hitachi L47x02a
Re: possible purchase Hitachi L47x02a
L47X02A is an LCD.
$15 each is pretty good, the Emerson would be easy to fix, then you could focus on the Hitachi.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
You only get 55" plasmas from Hitachi and Panasonic (2010 onwards), and as far as I know, Toshiba only ever used LG or Samsung plasma panels in their plasma TVs. Most likely it's a 52" LCD by Samsung (display panel) with tab bond defect, or a 55" LCD by LG Display (who have a small problem with some older display panels.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
It's bad tab bonds. Fix:
https://www.youtube.com/watch?v=xHst6pKLtTE
46" and 52" panels have half picture faults. Varies depending on the exact failure. 40" ones have full picture faults.
Go for $35, max, imo. Because you can so easily **** up the panel trying to fix tab bond issues, if you are careless.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Yep, that is tab bonds.
https://www.badcaps.net/forum/showth...371&highlight=Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Don't think it's a Tab Bond issue. could not find any issues with the tabs. so I was thinking bad panel then I noticed there was a spot that if I touched would clear up the picture. it looks like a testing pad?. used a small screw driver to make contact with the " pad " pad is marked in picture. panel is fine for now can't seem to get the panel to mess up anymore. but worried it's not fixed don't know why touching the pad with screw driver fixed the picture?Comment
The panel bondings are very sensitive and just flexing the board slightly can often temporarily fix the tab bonds. And sometimes it's not possible to see the problem, as it's not always visible.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
was touching them to no avail..only when I put my finger on the " pad " did the screen start to clear up.. the last time the screen was bad all I did was gently touch the pad with screw driver.. was about to give up because touching the tab bonds did not helpComment
Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
The TV was stuck on the logo and I couldn't access the update menu.
I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
The image result was good, but the image is inverted.
The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in... -
by wolf1976hi
i have the above tv and the display starts distorts the display at only in applications like you tube
after and on the didital channels
now without connect the antenna only the image of itsselfs tv i have the image i have in attach
i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?... -
by prodigy83My reference only: TT10141.
Problem: I need to purchase a mosfet chip from board 820-02100 M1 Pro, that is supposed to be Q5820 but according to Digikey, the schematic diagram I sent them, neither are relevant to the actual mosfet specification I sent them. I just basically need to find this mosfet to purchase, I cannot find it anywhere and am hoping someone could point me in the right direction without have to purchase this entire allusive board. Already checked with Digikey, Mouser, Aliexpress, eBay. Any suggestions?
Mosfet specs are as follows:
Chip markings:...1 Photo -
by massimomaxChiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
spero che qualcuno può averlo per riprogrammare eprom. grazie
Post in English !!!
I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
by dragometinTV Model: Hitachi 40HYC42
Power Supply: 17IPS71
MainBoard: 17MB95M
Panel: VES400UNDS-2D-NO3
When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
Is there any variants on 17IPS71 power supply's?
UART output pins 10 and 12 on scart connector:
Code:12:24:04.595
- Loading...
