LG lg52lb5d HDTV picture problem
    I have had this tv for about a year now, and during my last deployment my wife said it started having problems with the picture, the colors are very distorted, with no visible lines or anything. Well about two days after she told me it corrected itself. It did this two more times, well now it has done it again, and it wont fix itself. I opened the set up and noticed there are two or three blown caps on the main board, but would that cause picture issues? I thought that would cause power issues?
    I have attached two pictures that kind of capture the visual problems.
    Thanks for the help!!
    Re: LG lg52lb5d HDTV picture problem
    are the caps on the main board or power supply? if you are getting ripple on the caps or the powersupply is out of spec it could cause problems. change them out and see. i have fixed totally dead sets with a single cap change.
      Sorry I am new to tv repair. I have been repairing computers for awhile so i thought i would give tv's a shot. Is the main board the board with the all the inputs(a/v inputs)? Because the board I have found bad caps on had no inputs and its large next to the one with the inputs, i cannot put pics up tonight, because i needed to reassemble it to move it.
        you are proballt talking about the powersupply, rule of thumb if the power plug goes there then it is usually power supply.
          I looked up the internals of a generic lg tv, it appears i would be talking about the powersupply. So that could cause picture problems eh? I may have to order some caps here for it. Are you able to see the problem with the pictures i posted, i thought it might be kind of hard to tell what exactly im talking about, its almost like a cloud over it. But very distorted colors also.
            Here is an updated photo of the picture appears to be getting worse.
              do you have a voltmeter to check voltage out on power supply? they should be marked eg. 3.3, 5, 12 etc. it could be another problem but most likley it is voltage related. tom66 or bud m could probally answer better than me, but i always go to the voltages first.the thing about caps is the fact they dont always bloat or rupture, they can fail and give no visual indication. i use a peak 70 esr meter to identify the bad ones. it paid for itself in time saved on repairs on several sets. when tom gets here he can probally tell you more than me but i would guess caps causing ripple or lower than normal voltage.
                I do have a dmm, i just need to replace the fuse in it lol, blew it doing some automotive work. I will try to this tomorrow evening, gotta work tomorrow. I'm not familiar with an esr meter.
                  Most modern multimeters do not require a working fuse in order to measure voltage.
                  However, you do require a working fuse in order to measure current. Measuring current is something the regulars rarely ask people to do.
                  --- begin sig file ---
                  --- end sig file ---
                    Its a fluke multimeter when i went was measuring current on a alternator i went over the limit of the fuse, it will not read anything now. I will try again.
                    Thanks for all the input so far! I really appreciate it!
                      You were correct, it is still working I'm not sure what i was thinking.
                        i overlooked to mention you need the ground on the metal case and the power supply connected as working state. be carefull around the heatsinks they can be live.
                          Fluke fuses will cost anywhere between $6 and $12 each.
                          It sounds like you blew the 10A fuse. Most Flukes will read up to 20A for less than 30 seconds before blowing.
                          For car work, you may want to consider a DC clamp.
                          PS. Which Fluke model do you have?
                            Ill check the model of my dmm when i get to work. I have a dc clamp i just need it mailed to me.
                            Anything else i should check while i have it open?
                            I plan to replace the known bad capcitors and check power supply voltages.
                              look for any obvious signs of burned components, you may find the problem is with the caps.
