panasonic 12 gen "tc-p42g15" No video, no LED blinks
  • climbz
    • 4
    Hello all,
    Long time lurker, first time poster^^ I'm trying to figure out what is wrong w/ this panasonic tc-p42g15. I have taken some voltage readings and have a few question I hope somebody could help w/.
    First off here are the symptoms when plugging in the tv you hear a relay click. when you try to power the unit on the red LED beside the power button comes on and stays solid, after a few seconds the panels backlight will come on and go right back off, and the LED never changes/blinks, and you can't power down the tv w/o unplugging it.
    The measurments I've taken so far....
    P Board-
    TPVDA(tp9)-- 60v
    SS board-
    TPVSUS--208v
    TPSS1--134.2v
    TPVe---138.6
    TPSOS8---2.2 Mv
    SC Board-
    TPVSET--289
    TPVAD--194
    TPSC1--34.2
    TPVSUS--208.1
    TPVSCAN--46.2 @ Grnd Base
    TPSOS7--1.3Mv had some fluctuation but held at 1.3 eventually
    TPSOS6-- .6MV
    I've put the result that I don't know if they are correct or not in Orange.
    The voltage from the P board to the SS @ P11 is correct VSUS and the 15v.
    At P2 going from P board to the SC-the VSUS voltage is there.
    One thing I'm not sure about is at P25 connector at the "top" #1 I get 5v and on the next #2 I get 15v which is right. But after that #3 to the end of the connector approx 8-10 wires I don't know what the voltage should be if any.
    Also coming into the unit from the AC plug, the live and neutral sides each has their own fuse "f601, f602" from the it goes to a zdiode z601 and a cap c601---at this point the circut continues on, but @ cap 601 there is another diode 602 to a "bulb" of some sorts a601 to ground. My question is what is this bulb? Is it gas filled? I didn't see a filiment in it.
    Srry for the lengthy post, just trying to include any helpful information. I would like to know what else I should be testing or looking for, and any information or advice is much appreciated.
    here is a link to it https:http://******/TLeGRn
    Plasma 12th Generation Technical Guide - Panasonic
    Thanks in advance.
    ~Climbz
    Re: panasonic 12 gen "tc-p42g15" No video, no LED blinks
    Have you counted the number of blinks the LED does?
    It will blink N times, then pause, then blink N times, then pause.... This N indicates the fault code.
    • climbz
      • 4
      the LED stays solid the entire time. The only time that the LED blinks is when I disconnect one of the SC or SS boards from the P board. Then it will produce 7 blinks. But normally the LED is always solid. No blinks =/
      Thanks,
      ~Climbz
        OK, then it is most likely the A board.
        • climbz
          • 4
          Thanks Tom^^ I will look into it some more. I appreciate the reply and getting me pointed in at least some direction. I will post an update here once I find something out.
          ~Regards
          Climbz
          • Mt.Man
            • 53
            Here is the part# for the A board: TXN/A1FHUUS
            • climbz
              • 4
              UPDATE: the A-board is out of stock all over the interwebs--called panny sales and they quoted me 367.00 and it is on back order for 3-4 weeks. =/ Any information on the A board, like schematics or flow charts or any tips on isolation of the componet/s on the board would be a great help.
              Climbz
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • Hakuu
                by Hakuu
                Hi There,
                More Details
                TV Model - LG OLED77G1PUA
                07-12-2023, 02:37 PM
                by sam_sam_sam
                After all of...
                07-13-2024, 08:14 PM
              • canadaboy25
                Panasonic TC-P54VT25 No image. A or D board?
                by canadaboy25
                I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                01-17-2021, 01:06 AM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
