Vizio 3D m3d550kd parts interchange with m3d550kde?
  • gijoey198079
    • Dec 2012
    • 53
    So I have an opportunity to buy 2 vizio 3d led tvs really cheap but am curious about something and hope someone here might know the answer.
    The first tv is model m3d550kd and it powers on but the screen is shattered, the second is a m3d550kde that won't power on. I am just curious if the parts may be interchangeable?
    From what I can find the only known differences in specs are refresh rates, one is 120 and the other is 240. This leads me to think possibly different main boards or at least different software but I am thinking possibly the same power supply and connections. Any thoughts???
    Re: Vizio 3D m3d550kd parts interchange with m3d550kde?
    If it is an LED Vizio, it will most likely be using an LG-Philips LCD with a custom AmTRAN T-con board. You could probably swap the parts between them. Check ShopJimmy and other sites for images of the boards.
    • gijoey198079
      • Dec 2012
      • 53
      I've checked but they are both too new and no one carries parts for them yet that I have found.
      Would agree with the all LG parts internal, just wondering if they are interchangeble seeing how the specs are a bit different as far as colors and refresh rates.
      Oh, and yes it is a vizio led 3d hdtv
      • gijoey198079
        • Dec 2012
        • 53
        I can get both tvs for about 300-350 but that doesn't leave much room to order parts and make money so trying to make sure I can fix one with the 2.
          I dunno if I'd be willing to risk so much. It's nice to fix a 55", but I'd rather take less risk on (say) a 42" or 50".
          • ecking767
            • Oct 2009
            • 492
            My experience with Vizio LED/LCD TVs 120hz vs 240hz. The only common part will be the power supply. And maybe the LED driver board. That will be my guess.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • DXseekerMO
              Vizio D55un-E1, bad Q9100, C9100 & R9111, parts ordering questions
              by DXseekerMO
              Hello everyone, I just sourced a Vizio D55un-E1 with no status light at any time. Here's what I know:
              First referenced this thread: https://www.badcaps.net/forum/showth...light=d55un-e1
              Complaint: After a power outage the TV will not turn on with no indication of a status light.
              Findings: Complaint verified. Q9100 is short gate to source but neither of these are short to drain. R9111 is blown, board has a scorch mark next to the resistor. C9100 is blown with a hole in one side. U9101 appears unharmed as do the other board components....
              09-01-2021, 06:16 PM
            • JohnCT
              Parts ID for Vizio power board model E550i-B2 DPS-167DP-1
              by JohnCT
              The short story is that I have to repair board this for someone and it has the typical standby IC failure (LD7913, Schottkey, and Z909 4.7V zener), but someone has harvested some other zeners from the same circuit <sigh> before I got it. Everything else is there.
              I know this is a long shot, but has anyone ever documented the zener values in locations Z900, 902, 904, and 907? I assume there's no schematic of this board?
              Thanks.
              John
              01-06-2024, 01:11 PM
            • yankys
              vizio M3D550KDE Black & white picture
              by yankys
              HI everyone Pick up this 55" VIZIO tv that only plays in black and white picture doesn't matter what inputs HDMI or apps, but all the menus are in color, if you're on Netflix everything in color until you play any show. I'm thinking main board if so, can the board be reflowed to try and correct this?
              12-25-2022, 09:42 PM
            • mrtek
              Vizio M65-C1
              by mrtek
              Hi.
              picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
              When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
              This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
              07-14-2025, 07:28 PM
