Sony Bravia 52 LCD Vertical line
  • topfli8979
    • Oct 2012
    • 311
    Getting ready to pick up a sony bravia 52 LCD. Had one vertical line, now no picture at all. Everyone I talked to said bad lcd panel, just seeing if anyone has had this issue and repaired.
    Re: Sony Bravia 52 LCD Vertical line
    Hmm, there are probably two separate faults here. Vertical line is almost always bad panel, but no picture is t-con or main, usually.
    • topfli8979
      • Oct 2012
      • 311
      I was thinking t-con also, mainly because I have managed to fix vertical line problem before by reseating lvds cable or replacing tcon.
      • JUCaESAl
        Sony bravia KD-65AF9
        by JUCaESAl
        Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
        Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
        10-20-2025, 04:03 AM
      • otaku_nut
        Vizio E701i-A3 fixed but now has red vertical line
        by otaku_nut
        Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
        08-19-2025, 06:11 PM
      • TrueSword88
        Kogan - KALED65XU9220STB - Blue Vertical Line
        by TrueSword88
        Hi all.
        I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
        The line just happens to coincide with the end of COF and start of the next COF (attached).
        The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
        Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
        Hoping to fix...
        05-05-2023, 04:28 PM
      • PopsCaps
        Sony Bravia KDL-40V2500 that will not power on
        by PopsCaps
        I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
        I do not hear any sound and I cannot see any backlight.
        I have tried disconnecting every cable on each board one at a time to see if anything changes.
        The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
        My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
        03-25-2025, 11:23 AM
      • almarhum
        To fix laptop screen vertical line by working on its EDP cable
        by almarhum
        Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
        As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
        05-07-2024, 02:12 PM
