stubborn black pin connectors on X board Samsung PN58B560T5F
  • robgsamsung
    • Dec 2012
    • 15
    • usa
    Here is another probably ignorant question... the black pin connectors on the X board that go to X Buffers ( there are 4 of them) are very hard to pull apart. Am I missing some release. I do not want to force apart? and break something. Is there a trick to releasing or disconnecting the big black block pin connecters - attaching one board to another?
    Thank you
  • drpj23
    • May 2012
    • 528
    Re: stubborn black pin connectors on X board Samsung PN58B560T5F
    For those type, if I am thinking of the right ones, they are just pushed in (they might have a small groove for staying in) but there should be no snap. They are stubborn to get out because they are just firm connectors and there are 4. I usually take a large flat-head and start at one end and go down and just loosen each one little by little until it wants to come out (there should be a small space in-between the 2 circuit boards that are connected that you can put it in).
    You may have to work at it a little bit for you do not want to damage the PCB.
    • robgsamsung
      • Dec 2012
      • 15
      • usa
      Thank you ... sir. I thought that might be it, but there is nothing worse than forcing something and having it break I have gotten the jumping up and down ... over such a mistake ... pretty practiced over the years. In this case... practice never makes perfect... thanks to both you and Tom for having the time to help.
      Sincerely,
      Rob
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • ohren
        by ohren
        09-08-2023, 05:24 PM
      • C152Heavy
        by C152Heavy
        Summary for TL-DR readers:
        • VCC pin (18) of PFC...
        01-11-2023, 02:53 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
        09-07-2024, 05:50 AM
