Philips 21PT1357 CRT - bad Nichicon PR
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    This one arrived last night. Owner's description: Works for 5 minutes then picture starts wobbling.
    Popped the back off today, and we have a bloated cap. A Nichicon no less... It's a Nichicon PR 47u 160v. It appears to be the cap after the pi filter on the B+ rail. The capacitor read open on the ESR meter. Replaced with a Ruby, TV is now working fine. A little searching reveals that this particular cap appears to be a common issue with this model.
    Otherwise, the TV is pretty nicely built, all Nichicon and Rubycon caps. Unfortunately this series is notorious for bad geometry from the factory, and this was no exception. Needed a few tweaks in the service menu. The picture quality is very good tho. If i'm correct, this set should be around 6-7 years old, the manufacturing date wasn't printed on the back, and i can't be bothered to look for it elsewhere.
    Interesting bit is the other cap on B+ is another Nichicon PR 47u 160v which is fine - but it's in a larger can size as you can see. The Ruby i put in is in that larger can size as well. I'm leaning towards a design mistake, the cap's ripple current rating could have been exceeded, and that's what caused it to bloat. I can't see other reasons - it's definitely not heat.
    A working TV? How boring!
    Re: Philips 21PT1357 CRT - bad Nichicon PR
    Hmm, interesting. Is it definitely before the pi filter? Otherwise, Nichicon seem to be the least reliable of all the good brands (but still very good.)
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      The bloated Nichicon PR was after the pi filter like i mentioned. It's marked C2409 in the service manual which you can find on elektrotanya, just google "philips chassis L01.2E.AA" and you'll find it if you want to take a look. It filters the B+ rail going into the flyback. In between the two caps is a 27uH inductor.
      Otherwise it would really have made no sense to put a larger can after the pi filter, than before.
        Sorry, I meant to say "definitely after the pi filter"
        It does seem like some PSUs are unstable with a higher capacitance on the output of a pi filter, than on the input, but I have seen a few power supplies which do this. Might be related to the compensation?
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          I don't think i've yet seen a TV that has feedback taken after the pi filter. I think it's simply the case that the high energy pulses taken by the flyback resulted in excess ripple and low voltage on the outputs that are derived from it.
            I have seen a poorly designed wall wart with 200mVp-p of ripple which had feedback after pi filter, moved feedback, ripple dropped to a tenth of that.
            • DrewPhillips
              Capacitor Diarrhea - Nichicon PL Series
              by DrewPhillips
              Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
              The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
              03-02-2025, 10:18 PM
            • alro7779
              Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
              by alro7779
              Hello, guys!
              The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
              09-14-2025, 12:25 AM
            • G33RT
              Philips 8200 series 65PUS8204/12 stuck at Philips Logo
              by G33RT
              Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
              It does power up when pressing the power button.
              I already try the power button while plugin the plug with no result.
              Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
              Could this be an PSU or eMMC issue ?
              07-19-2025, 03:43 AM
            • nick3092
              Mid/late 80's Nichicon Yellow Caps
              by nick3092
              I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
              08-28-2022, 03:56 PM
            • double_DD
              Philips curling iron - is this a common AC cable?
              by double_DD
              Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
              As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
              Not sure if this is something Philips proprietary, or a standard, but the cable plug...
              08-18-2025, 10:04 AM
