Value of replacement for 6632L-0470A & 0471A inverter
  • jbfr_54
    • Dec 2012
    • 52
    • France
    As I am a new member from France, I am happy to join the forum which I often searched for technical advice on TV set repair.
    I have a Philips 42PFL7662D with bad inverters. I changed the IC and the four Mosfets on the Master board but no progress, backlight still failing while slave board loks fine..
    I found equivalent boards on sale in different locations for a reasonable price.
    These are 6632L-0535A and 0535B, advertised as equivalent in size, screw holes and power but cable locations seem different.
    As anyone had experience with these new boards ? Any advice ?
    Thanks in advance for your support.
    Happy New Year
    Jean
    Re: Value of replacement for 6632L-0470A & 0471A inverter
    An inverter is an inverter. In the vast majority of cases, if the power connector and output connectors are the same, it will work…
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      I'm confused as to why you would first consider the inverters to be bad?? What are the symptoms? You say that the IC and the mosfets were changed out on the master but not the slave. Once again... what made you do this? Resistance readings??
      Check my post here: https://www.badcaps.net/forum/showpo...4&postcount=29
      Follow the instructions for testing both boards and post your results.
      • jbfr_54
        • Dec 2012
        • 52
        • France
        In the meantime I found my problem, in fact the BD9897 IC (brand new) was bad, I probably blew it up when soldering. When testing the Master board, I short circuited pins 28 and 29 resulting in a Zener blown (placed on pin 28 of the IC and GND).
        I replace again the BD9897 and placed a 6,2v Zener (forgot the diode identification on PCB but it's a SMD Zener marked E2 which semms to be 6.2 volts (it's placed between pin 28 REG and ground). Checked everything again and powered the TV !
        The Master PCB shows a blue LED on for a couple of seconds, then off, then I hear a little "tick" noise from the PCB and at the same time the backlight flashes shortly, then a few seconds later the blue LED comes on again and finally the backlight switches ON.
        This "two steps" cycle to turn on the backlight occurs each time I turn on the TV and I wonder if it is normal. Does anyone knows about this ?
        I have 6.2 volts on the REG pin of the BD9897. Is this the normal voltage, I expected 5.5 to 6 volts according to datasheet) ?
        Next step, I will apply the recommended modifications of the circuit !
        Thaks in advance for your help.
        Jean
        • eccerr0r
          inverter H tree driver imbalance in an AC inverter
          by eccerr0r
          My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
          Today, 12:34 PM
        • x_orange90_x
          Vizio E55-E1 bad backlights or bad inverter?
          by x_orange90_x
          I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
          I don't know how exactly to test the inverter itself. Is it...
          01-29-2025, 09:24 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • jdbird613
          Power Inverter Replacement Circuit Board Question?
          by jdbird613
          So my Ampeak 2000 watt power inverter will receive power from a 12 volt source, and also has a display screen that displays how many volts the inverter is currently using...However, the plug outputs are not producing any power outward...The display screen on the inverter also shows how many volts an item that is plugged in is currently using...Which stays at 0 and no items will power on...I opened the inverter casing and discovered there is some charring and burned areas on one end of the circuit board...What I am trying to figure out is if I can purchase/obtain a new board exactly like the board...
          02-27-2020, 08:37 AM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
